Question about RCA HD52W59 HDTV Projection Television
Same problem with TV
I have teh same problem with my HD52W59. It burned a small hole on a board located on the left side of the tv (if looking from the back). What board is it and do you know where I can fine a replacement??? Thanks!
  • RCA Master
  • 2,794 Answers
You will have to get a technician to get it for you in your area.
Posted on Jun 13, 2008
I have a rca hd52w59 tv. turned it on this morning and it made a snowy noise in the back and shut off. what is the problem/ expensive to repair/
Most likely problem is the Flyback has shorted or CL031 has burned a hole through the deflection board both on the deflection board. Replaceing the deflection board is the best way to repair the issue. You can get replacement deflection boards for your model at www.tvrepairworld.com
Jun 14, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
My rca hd '52" tv has a bow in it & colors dont line up
Blowed Fuse FL231 will be on right handside of FBT flyback Transfomer there is 3 of them in a Roll small brown looking caps But they are Fuses it will be the one in the Middle Located on your Deflection Board which is the Bottom left hand side Board. www.Partstore.com for Fuse
Dec 21, 2009 | RCA HD52W59 HDTV Projection Television
Pic has a big bow in it and the colors don,tline up, went and had a new convergence board installed and still have the same problem
Is the convergence option still listed under the on screen menu's setting options or has it disappeared? Let me know and will assist you with the problem.
Dec 14, 2009 | RCA HD52W59 HDTV Projection Television
My power cord fell off. Took off the back of the
there is a small board with a small transformer . the plug is located next to that small transformer. if the cord originally came from the right hand side if you are looking at tv from the back. the plug is on that right board. if the tv cord came from the left side, the plug is located on the main board in the front of tv. the plug in both situations are the same, it is white in color and has 2 or three pins sticking straight up.
Nov 15, 2009 | Sony KV-32FS13 TV
RCA HD52W59 TV Convergence problem
it is not to bad if Convergence are not moveing by the flyback
you see 3 fuse look like litte box in a row hit
tham, if the led in front of tv blink more then one your fly back is bad to,as you look at the board look at the cap.s on your board you see a cap,it a bout to blow. hope this help you out.
Aug 25, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
you can get any board needed at the following link for your model its the ITC222 chassis, they have pictures of the various boards so you can deyermine which board it is that youre needing. Heres the link.
http://servicemanuals.vstore.ca/
Aug 24, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
check the fuse its located on the small rectangle board which is on the right side looking in the back its the board closet to where the screen is.
May 12, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
19 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
