Question about Intel Motherboard
My motherboard GA-8GGEM800 no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
My motherboard 945gs no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
Posted on Nov 06, 2010
SOURCE:
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
I have a intel dual core 3ghz cpu my mother board is Intel DG41RQ main board when on my computer the CPU fan is running but no display i check the CPU & ram and monitor that works fine on...
hello there
it seems that your on-board video card having trouble, try to put external video card to your system and power up your computer.
thanks.
Mar 01, 2011 | Gigabyte GA-M61P-S3 Motherboard
GA-7N400 Pro2 at startup i hawe long separate continus beeps
Possibly Ram, try and see if removing and replacing helps
Other causes may be voltage issues ( check the bios and see what the various rails are telling you)
eg: there should be readings for 12 volts 5 volts and 3 volts, if any are + or - by 10%, there is an issue with the voltge controller. You might want to try a replacement PSU?
After this.. bad video ( check by installing a video card)
Temperature warnings ( check in bios to see under PC health status) what the cpu and board temps are running at, if above 70 degrees...overheating issue or more likely at start up, board thinks that the CPU fan is not running fast enough or not working. If fan IS working, you have a problem with the CPU fan sensor, will need to replace mobo
Jan 27, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
Mother board power is on then shut down 15 seconds.how to solve this problem.
first : check the biose of the board ,try to updat the biose .
2nd: check the ram fixed in board if its ok then check the bus
of the ram & board bus
3d: finally check if cpu work corroctly by replacing cpu .
Sep 18, 2010 | Gigabyte GA-K8VM800M Motherboard
I have a problem with my board Gigabyte GA-G31M-ES2L, encounter no display & no beeps even though I remove the RAM in the board please help me to solve this problem?
Do the fans still start spinning ? And did you do a CMOS clear ?
You should also try booting it without a graphics card and/or any other audio/network card, etc, so you only have the CPU and motherboard (and also try it with 1 RAM bank and without). When it beeps, it's probably alright (implicating other failing hardware).
When you hear no beeps at all (but the fans spin), it's pretty likely that the board is gone. You might want to doublecheck the powersupply and CPU nevertheless.
Aug 18, 2009 | Gigabyte GA-G31M-ES2L Motherboard
Well my system temperature is reaching heats of 50oc under load and I believe it is making my computer freeze causing me to restart. I was wondering how exactly this temperature is measured and where...
Many motherboards take two temps. Motherboard temp and CPU temp. CPU temp is the most common problem. Check there first. You might need a faster fan or a larger heat sink. Also make sure the pc isn't enclosed in anything. It needs to have air moving around it on both main sides, the front and back.
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Problem with GA 8LD533
There are a few easy fixes for this, first,
Clear the CMOS (Unplug the power cord, remove the battery, and (if it's an option) move the jumper J1 (it has three pins, the jumper covers two, move it to cover the other one), unplug everything external from the motherboard apart from the PSU and power switch and speaker, replace battery, powercord, and jp1, power up - what happens?
Nov 19, 2007 | Gigabyte GA-8LD533(-P) microATX...
Intel Motherboard Logo
126 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
