Question about Altec Lansing AVS 500 Computer Speakers
AVS 500 subwoofer speaker
Just wondering if you know whether the wiring input from the 18 volt adapter is is negative or positive? I purchased the speakers second hand and there is no indication on the side of the subwoofer as to whether it is a negative or positive. The company seems to be no help whatsoever..
Thanks,
Peter.
  • 24 Answers
About that Model AVS-500, as shown in picture above-left. The Class 2 Transformer Model No. 9701-00648-I UND from AMC (OEM ALTEC), is not 26 and 26 V, it is Input: AC120V-60Hz 28.5Volts. Output: DC18V 1000mA. This info is from the original part, should you need to buy a Transformer to power the system. Truly a wonderful set!
http://www.razorinnovation.com
Posted on Jan 29, 2013
    Scholar:
  • 82 Answers
If you have a digital tester just select DC voltage then connect the positive leads of the digital tester to any of the wire coming out of the 18V adapter (WARNING do not connect to the wire connected to the main) and then the other lead of the digital tester which is the negative connected to the other wire of the 18V adaptor. If in the screen of the digital adapter reads a negative value, then it indicates that the other wire is the negative and the other is positive. Otherwise if the tester reads a positive value then your tester's leads have got the right connection.
P.S. please rate me.
Posted on Jun 25, 2008
I have lost the power cord to my avs 500 speakers, can you tell me what I need to get them going again
Posted on Jan 03, 2009
Hello, I need to know the wiring connection destinations by color for all wires coming out of the back of the Pioneer DEH-P9200R car audio receiver. Thanks in advance. John from Baltimore
If this helps you then please help my rating,voting for me would be great too thanks.
Black - Ground
Blue - Power Antenna / Control for an AMP
Orange - Constant 12 Volts
Red - 12 Volts when the ignition is on, 0 Volts when it's off
[Speakers]
[Front]
Gray - Front Right Positive
Gray Black - Front Right Negative
Green - Front Left Positive
Green Black - Front Left Negative
[Rear]
Gray Red - Right Rear Positive
Black Gray - Right Rear Negative
Green red - Left Rear Positive
Black Green - Left Rear Negative
Nov 15, 2010 | Car Audio & Video
Negative and positive termanals not marked on speaker for instqllation does it matter?
It matters. Get a 9-volt battery and touch it to the terminals. When the positive side of the 9-volt is connected to the positive speaker terminal, the cone will pop out. If it pops in, then the positive side of the battery is touching the negative speaker terminal.
NOTE: A subwoofer should be strong enough to handle this. If you try this with a small speaker you can damage it!
Nov 08, 2010 | Pyle (PLBW124) Car Subwoofer
I need to wire up a rockford fosgate punch hx2 12" subwoofer to a 500 watt single channel amp and i need to know how to wire the dual voice coil properly ??
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1212 Car...
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
I am wondering how to install neon speaker rings I have 2 10" rings and i cant figure out how to wire them together, can anybody help me with that?
the speaker neon lights can be wired in directly from the negative and positive speaker wires by simply splicing them. in most casses this also causes the lights to pulsate with the music. in most 12 volt applications the positive and negative wires are generally transferable and do not cause damage when hooked up in reverse
hope it helps
ryan
Jan 03, 2009 | Car Audio & Video
12"volfenhag subwoofers
use a 9volt battery, touch both wires to the battery connections, if the speaker jumps upward and away from the magnet, the wire on the positive (+) terminal of the nine volt is positive (Red), if the speaker jumps inward towards the magnet, then the wire on the positive (+) terminal of the nine volt is negative (Black). CAUTION: only TAP the wires to the nine volt terminals briefly, if you hold them on there it may damage the speakers voice coils, (or other parts.) best of luck!
Oct 25, 2008 | Volfenhag ZX-4712 Car Subwoofer
Voltage adapter
NO, it is very under rated and powered. You need an 18 volt and not a 12 VOLT. They should not be that hard to find in an electronics store. Also the amp rating is also important. Make sure you are matching both amps and volts AC or DC to the the label on the woofer or you could end up blowing the out.
Sep 24, 2008 | Altec Lansing AVS 300 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing AVS 500 Computer Speakers Logo
265 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
