HP LaserJet 3600n Printer Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I will like to install hp color laserjet 3600n on a network,but I can't be able to edit the ip.It only show 2 options Auto and off.Please tell me what to do.configuration page displays this ip 192.0.0.192
Anonymous
Level 3:
  • HP Master 32,281 Answers
  • Posted on Oct 28, 2010
Anonymous
HP Master
Level 3:
Answers
32281
Questions
Helped
7908049
Points
102259
To setup a HP laser printer with a JetDirect print server card on a network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
PCL XL error on HP color laserjet 3600n
Verify printer functionalityTo verify printer functionality, use the following steps:
  1. Turn off the printer and then unplug the Parallel, Serial, or Network data cable from the back of the printer. This will ensure that the information is not being received from the computer or network.
  2. Turn on the printer and verify that the word Ready appears on the printer display.
  3. Print a self-test on the printer by performing the following steps:
    1. Go to the on the printer.
    2. Press the MENU key until INFORMATION MENU appears on the printer display.
    3. Press the Item key until PRINT MENU MAP appears on the printer display.
    4. Press the SELECT button. The printer should generate a print job.
Try to print a page using the software application or a document in question after attempting each item of the following workaround. This will help determine if the changes made have caused the desired results to occur.
  1. Connect the printer directly to the computer. Use an IEEE/1284-compliant cable.
  2. Print a Test Page by completing the following steps:
    1. Click Start and then Settings and Printers .
    2. Right-click the appropriate printer driver.
    3. Select Properties .
    4. Click the General tab and click the button in the lower right-hand corner that is labeledPrint Test Page .
If the error is not resolved, try a different IEEE 1284-compliant cable. If there is no possibility to direct connect, use a different network cable, or network port, on the hub. Simplify communication options depending on the specific printer. Use the Control Panel on the printer to turn off High Speed andAdvanced Functions . To turn off High Speed and Advanced Functions complete the following steps:
  1. Press the MENU key.
  2. Select CONFIGURE DEVICE .
  3. Press I/O MENU and disable Parallel High Speed .
  4. Press I/O MENU and disable Advanced Functions .
  5. Connect the printer to a different location, change parallel/USB/network cables. Bypass switch/hub (if there is any).
For problems with certain applications or documents, try modifying the HP LaserJet printer series PCL6 driver settings, such as:
  • Use lower resolution, such as 600 dpi.
  • Enable or disable Send True Type as Bitmaps .
  • Disable the Print Optimization under Printer Properties => Advanced => Document Option .
Some more steps:
  • Try changing the personality type to Auto/PCL/PS in printer Control Panel.
  • If changing personality does not make any difference, remove the current driver completely (from Server Properties ), restart the system, and install PostScript (PS) driver.
  • While installing the printer driver, select the standard TCP/IP port if the default is HP Port , and vice-versa.
General troubleshooting tipsContinue to isolate the error by printing the job in question after applying each of the following suggestions:
  1. Remove any additional memory that has been added to the printer after being purchased. Refer to the User's Manual that was supplied with the printer for memory removal instructions.
  2. Try using a different Font within the application or document in question.
  3. Try to print using the PCL5e driver that came with the HP LaserJet Printing System.
I installed a new router on our small network and now our hp 4600 color laserjet printer shows offline and will not come online no matter what I try.
First, make sure your Router is configured for DHCP, and the Printer is plugged into the Router using a Network Cable. Also, make sure the Activity light on your Router is On for the Port that your plugged the Printer into.
Configuring TCP/IP parameters
You can use the printer control panel to configure the following TCP/IP parameters:
  • usage of the BOOTP file for configuration parameters (the default is to use the BOOTP file)
  • IP address (4 bytes)
  • subnet mask (4 bytes)
  • default gateway (4 bytes)
  • TCP/IP connection timeout (in seconds)
Note: Do not disable BOOTP if you will be using RARP or DHCP to configure TCP/IP parameters.
To automatically configure TCP/IP parameters from the printer control panel:
1. Press the Check Mark button to enter the MENUS.
2. Press the Down Arrow to highlight CONFIGURE DEVICE.
3. Press the Check Mark button to select CONFIGURE DEVICE.
4. Press the Down Arrow to highlight I/O.
5. Press the Check Mark button to select I/O.
6. Press the Down Arrow to highlight EIO X (where X = 1, 2, or 3).
7. Press the Check Mark button to select EIO X.
8. Press the Down Arrow to highlight AUTO.
9. Press the Check Mark button to select AUTO.
10. Press the PAUSE/RESUME button to return to the READY state.
Here is your Manual, with more information about Network Configuration:
http://business.fsu.edu/tech/printermanuals/laserprinters/HP4600.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Hp color laserjet 3600n printer
http://reviews.cnet.com/laser-printers/hp-color-laserjet-3600n/4505-3159_7-31557358.html
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-3328060-15077-236268-501044-501046-501395.html
I have a networked HP 3600n printer.\r\n when printing in grey scale it prints in reverse, so the black is the back ground and the writing is white. Can anyone please advise? The OS is XP and the server...
The "Mirror Image " printing option is enabled.
Click on START - Control Panel - Printers and Faxes. You will find list of Printers Installed
select the HP 3600n Printer icon and right click on it. Select Printing Preferences. Under Advanced Features you will find "Mirror Image" - Choose OFF and Click ok and Save the settings and try printing.
6helpful
Error 51.23 on HP 3600 color laserjet printer
3helpful
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
k24674
Grand Canyon Tech
Grand Canyon Tech
