Question about Irons
Instructions for use DiLonghi StiroMeglio compact iron (steam boiler Iron)
Hi, I have the above iron and have never been able to use it I received it as a gift. I do no have instructions with it. I fill the boiler with water and the steam biulds up inside but I am unable to get the steam to go through to the iron. There is a button at thumb level on the the handle which I assumed would be held down or released for steam but no steam gets through the iron either way. I am afraid to leave the boiler on for too long so I give up trying after about five minutes after boil. Is there something I should be or should not be doing. Regards Elizabeth
  • libbybe Jun 10, 2008
    DeLonghi StiroMeglio compact steam Iron is the above model
  • Anonymous Jul 10, 2008
    I am unable to get any steam coming through to the hotplate on the iron. How can I fix this problem? Is it clogged up somehow?
    Scholar:
  • 65 Answers
Is a long story but i make short.Don`t be afraid to leave your iron on.Is common to water tank iron to get working in more then 5-10 minutes.That machine are really safe since they do have more then 1 thermostat to control the water pressure.
How they work is pretty easy.The boil the water to a certan temperature and you know after certan F. the water become steam generatin pressure and steam.The thermostat control the heater and the electroswitch release the steam
If your in not making any steam after 5-10 minutes make sure you hear the electroswitch working.Sometimes they get cloght and even if the boil is under the pressure you can not get any steam at all
Good Luck
Posted on Jun 19, 2008
Heat element light comes on (so there is power) but the iron will not hear up
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
Apr 24, 2014 | DeLonghi Stiromeglio Compact PRO 300 Iron
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
My iron exploded when I plugged it in. How can it be fixed?
You have a short in the wiring inside of the iron. It will not work until you get the short fixed.
Oct 31, 2012 | DeLonghi Stiromeglio Compact PRO 300 Iron
Steam boiler iron
you can download instr. manual from www. fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
service manual go www.pdfservicemanual.com
God bless you. However see the diagram is universal for repair small appliances.
Jul 25, 2012 | Irons
I am unable to stop the steam at the iron. The trigger doesn't appear to be stuck.
I would first try with household vinegar (empty as much water as possible) and if that doesn't work to free the valve, then something more aggressive containing acid like any of the Lime Away type of lime/rust removers. If it is still stuck, you may have to bet the iron hot to make the acid more effective. If using other than vinegar, I wouldn't advise allowing anyone to breath the vapors; do this in a utility room or basement.
That trigger probably acts on a needle valve that controls the flow of water to the point at which it is turned to steam and it may simply be too contaminated with lime buildup to slip back into the valve body.
Jan 10, 2010 | DeLonghi Stiromeglio Compact PRO 300 Iron
The boiler part is working fine but i have no
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 25, 2009 | DeLonghi Stiromeglio Compact PRO 300 Iron
Steam not working
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 06, 2008 | Conair Compact Garment Steamer Iron
Steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Apr 16, 2008 | Rowenta DG-980 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
307 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
