Question about Microwave Ovens
DOOR ON MY 1998 R-530BS MICROWAVE OVEN WILL NOT OPEN.
I HAVE TRIED WD 40 BUT IT STILL DID NOT WORK.  I FINALLY GOT IT OPEN WITH A SHARP RAP WITH THE HANDLE OF A SCREW DRIVER, BUT THAT IS THE ONLY WAY.  IT HAS WORKED FOR 10 YEARS.  I ADDED MORE WD 4O DIRECTLY INTO THE DOOR HOLES.  WHAT NEXT?
  • Microwave Ovens Master
  • 9,098 Answers
There may be a grease buildup on the sides of the door open button.
Or there may be enough wear on the prong ends of the back side of the door open button or the face of the door open lever so that it is not pushing the latches up high enough to open the door.
The outer cover will need to be removed to diagnose and repair this.
You can find an exploded view by entering your model number here: http://www.searspartsdirect.com
On the exploded views, the door open lever is reference # 2-6 and the door open button is reference # 3-5.
The best place to order Sharp parts is Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 05, 2008
Push botton for sharp microwave sticks when you press it to open
Hold the latch in and spray some WD-40 penetrating fluid through top.
If this doesn't free it remove the phillips head screw under the bottom right forward corner and pull the control panel out from the bottom to access the latch
Jul 12, 2014 | Sharp Microwave Ovens
Door of sharp microwave will not open
Take it back, if this becomes a problem then you will have a harder time getting customer satisfaction.
Jul 09, 2012 | Sharp R-930AK Convection/Microwave Oven
My GE JE1640GB MW kept running after I was done using it. I held down the Off button to try and reset it, which locked the unit (unit reads "Lock" and diplays an L when running). I need to...
Thank you so much for the info. The WD 40 worked perfectly on the door and my microwave in not turning on every time the door is opened. This info saved me time and $. Thanks
Dec 01, 2010 | GE JE1640 Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
SERVICE STICKER LEAVES MARK ON FRONT DOOR OF MICROWAVE
if you spray wd 40 or a light oil on a rag and work it into the glue this will break down the glue and make it easier to clean up.
Hope that helps...
Lbcoaster
Dec 29, 2008 | Sharp R-1610 Microwave Oven
The door on my Sharp Carousel II Microwave Oven will not open. The display says LOCK. Looking at my booklet revealed that there is a safety lock feature. I tried to cancel by touching Autostart/clock,...
Sounds like a drawer type microwave or a combo oven and microwave?
If your manual's instructions didn't fix it, you can try a hard reset.
Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you still need help, please reply back with your model number so we can help you.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Sharp Microwave Ovens
Sharp R-204CW microwave,won't start at all
try to slam the door and try again. sometimes the micro switch at the door are getting sticky and would not latch correctly. if it work, open the housing and spray some wd-40 on the door latches.
Feb 17, 2008 | Microwave Ovens
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
The door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
Mar 15, 2006 | Emerson MW8987B/W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
