Question about Kenwood KDC-135 CD Player
CD Player shuts off
My cd player is in a boat, when you turn the volume up to about 28 the unit shuts off and then turns back on. It plays fine when the volume is below 28. Is there some kind of protection on the unit that I could shut off??? And how would I do that???
    President:
  • 624 Answers
Since it is in a boat you may have some slight water damage.You should take it in to be cleaned very soon. The longer you wait the worse it will get if this is the problem.
if you are planning on fixing it yourself you wil need to take it apart completley (be careful and don't force anything out) and look it over for any little bit of corrosion on both sides of the main board.
If you do not have the proper chemicals to clean it, you can use isoproyl alcohol and an old toothbrush to clean any corrosion on the board.You may also need some solder joints reflowed as well.
They do have a protection circuit, but there is no way to disable it easy. You would need to lift the proper pin (87 & 89 on IC1) on the microprocessor, but that is not a good idea ever. They go into protect to minimize any damage that could be caused. It would also be a fire hazard if it does not shut down when these things are detected.
If this is not the problem, you may need the amp IC replaced or you may have a speaker that is starting to go bad.
Posted on Jun 18, 2008
2008 Kia Grand Carnival, cd plays but no sound. Audio works fine for radio
Try cleaning the CD player with a cleaning disc, that is the best way to troubleshoot this at a less costly price tag.
Nov 23, 2013 | Car Audio & Video
Regarding a Yamaha RX-V757 receiver, if I have my volume set above approximately -28, whether I'm playing a DVD or listening to a music CD, the units power shutsoff. When I turn it back on the display says...
Try turning up the volume with just the FM selected (and tuned to a station). If you can adjust the volume to an appreciably higher level when simply tuning in a radio station, then your CD/DVD player may be outputting a signal with a DC offset, which is getting amplified when you turn up the volume, and past a certain point the protection circuitry is sensing too much DC being sent to the speakers and shuts the unit down. If the unit is getting hot, there is likely an internal problem, or you have a shorted speaker wire, or even a bad speaker. Replace the speaker wires as a test, and you can also run the unit with only one speaker connected at a time to see if any are the source of your problem.
Yes, it's possible that there's nothing wrong with the wires or the speakers, and the unit simply needs a trip to the shop, but it's your job to rule out the easy stuff before you pack it up and take it in.
Nov 21, 2009 | Yamaha Audio Players & Recorders
Volume Control Problems
if the volume control is a rotary dial. The dial itself has gone bad or is worn out.  I'd most likely replace the unit as repair will be about the same price or more.  Buy an mp3 player instead.
Mar 29, 2009 | Durabrand Anti-Skip CD-915 Personal CD...
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
My cd player works intermittently
i dunno wot is happenin but the same thing is happenin 2 my cd player nd it reli annoyin! please sum1 help!!!
Aug 28, 2008 | JVC KD-SX980 CD Player
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
Problem playing CD
Does this CD play in any other unit?
Does your player other CDs fine?
Oct 20, 2007 | Panasonic CQ-CB9900U CD Player
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
Aux port doesn't show; Button is Stuck
I don't know if you have figured out how to turn the AUX port on yet, but I just figured it out. First, turn the CD Player off by quickly pushing the "Source" button. This is also the volume knob. Then, after the player is off, hold down the "Source" button. This will bring up the initial setup. Use the arrow keys to navigate through the options. One of the options is to turn the AUX port on. Once this is finished, turn the unit back on and you're ready to go.
Jan 22, 2007 | Pioneer DEH-P4800MP CD Player
Kenwood KDC-135 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
