Question about Sirius STILETTO 100 MP3 Player
Sampling rate... I get an error stating that "your device does not support the sampling rate of this file." Is there a way to fix this???? Thanks a ton for any help!
  • 8,596 Answers
If the file is a non-DRM encrypted WMA file, you can certianly change this. My personal favorite program (free) to use is Media Monkey, but you can use any program. You just convert the file format, and it will give you "Sampling Rate" as an option. You can change the sampling rate to one that is accepted by your mp3 player.
Posted on Jun 10, 2008
USB containing MP3's is inserted but deck says "unsupported" and will not display songs. I transferred songs on an IMac to the USB if that matters.
Using an unsupported USB device can result in abnormal playback or display of the audio file. Even if you use the USB device conforming to the above specs, audio files cannot be played normally depending on the type or condition of the USB device.
Feb 21, 2016 | Alpine CDE-143BT Advanced Bluetooth CD...
Bit Rate
CD media We speak about AudioCD, not about MP3 collections: these are two absolutely different things. Audio CDs offer reference sound quality, because they capture everything without any clipping or compression. What concerns MP3 collections, they are just compressed CD tracks recorded on a CD. Music in AudioCD format has strict technical parameters, which cannot be changed. That's why it's possible to calculate the total length of a disc - 74 or 80 minutes (an album may be shorter, of course). You can copy music from a CD to your computer, but it's not very easy. In order to save your music to a hard drive, CD tracks should be encoded into any audio format. You can do it with various programs - for example, Windows Media Player, which can be found in most computers. The audio quality will depend on encoding options. The higher audio quality, the larger your audio files will be. However, this is already the next point :) Uncompressed media Digital data from a CD can be read 1:1 and recorded as a WAV PCM file. As no details are lost, this operation is fully reversible - you can record a CD from your files. It will be almost the same or absolutely identical (if you didn't break tracks into files) as the original CD. The advantage of this format is that it's lossless. However, from the point of view of portable devices, such files are too big: one minute of music in this format requires over 10 MB of disc space. Besides, WAV support is not available in all players: HDD players tend to support this format, while flash players usually don't. Lossy compression There exist methods to compress music, when some audio data are lost. For example, MP3, WMA, OGG, AAC, etc. It's these formats that are supported by all modern players. But this support is limited. For example, any player supports MP3. WMA is supported by 3/4 of the modern devices. However, only 30-40% of modern players support OGG and AAC. Lossless compression An encoding program can compress original audio from a CD several times. However, the file size is relatively big - a usual CD can be compressed twofold. However, original audio is not clipped. While lossy formats just sound like the original audio CD, lossless formats provide original sound, which is compressed to take less storage space. There are several lossless codecs and formats. The most popular is the format used by Apple - it's supported in all iPods but shuffle. You may also come across such formats as FLAC and APE. These formats are especially promising from the point of view of their top audio quality - they are no worse than WAV PCM, but they take up 50% less storage space and they support tags (we'll touch upon them below). Regardless of a format, music files differ by compression quality. The main parameters here are bit rate and sampling rate. Bit rates vary much in music files. The higher the bit rate (all other things being equal), the higher the audio quality. The highest audio quality is provided by bit rates starting from 128 Kbps and higher. Lower bit rates are used only when audio quality is not critical, for example for voice recording. Besides, it's agreed that 320 Kbps hardly differs from the original audio track. However, it's a subjective factor, which depends on a given person, ear for music, and sensitivity. By the way, the bit rate of audio CDs is 1411 Kbps. As we can see, there is a great difference between compressed and uncompressed audio. Audio file size grows proportionally to its bit rate. The lower the bit rate, the smaller the audio file, the lower audio quality, and vice versa. Let's describe the notions of bit rate and sampling rate.
Bit rate shows how much data is required to encode one second of an audio file. So, when the bit rate of a file equals 256 Kbps, it means that each second of this audio file takes 256 Kbit of memory. So you can calculate the size of a music file, if you know its length and bit rate. Another definition of this term is a bitstream. It's often used to describe audio microcontrollers. It's easier to understand this term from the point of view of interface throughput: how much bits are processed (go through a given interface) per second. It's impossible to say which bit rate to use to encode audio - it's a subjective matter. One user will be always satisfied with 128 Kbps, the other will grumble about 320 Kbps.
Sampling rate—it resembles video resolution: the higher it is, the more details you will see. What concerns sampling rate, the higher it is, the more distinctly a file sounds. So the higher the better. The optimal quality is usually provided by the sampling rate of 44100 Hz (it's often called 44 kHz). This value is not chosen at random - according to the sampling theorem, a sampling rate of a signal must be at least twice as high as the rate of the source signal (if you know physics well, don't write angry emails to us, we simplified it deliberately ;)). As a human ear distinguishes sounds from 20-30 Hz to 20-22 kHz, we should use 40-44 kHz for digital audio processing. The standard of professional equipment is 48 kHz - with a little safety margin. But when the AudioCD standard was created, its authors did not want to compete with professional equipment, so the sampling rate was cut down to 44 kHz. Computer formats support even higher values. But as most music tracks are copied from AudioCDs, there is nothing surprising about this value being the widest spread sampling rate.
This theorem gives only a necessity criterion, not a sufficiency criterion. That is, we know for sure that if we don't provide the twice as high sampling rate, the audio quality will definitely be bad... But we don't know whether it will be good, if we do. And we don't know the exact sampling rate to ensure good audio quality :) That's why the 48 kHz sampling rate is used in DVDs and professional audio equipment, and HD audio (for example, SACD or DVD Audio) supports sampling rates of 96 kHz or even 192 kHz, because even 48 kHz may be insufficient. However, there is no need to support these excesses in portable players :)
What does it all mean in practice? Here is a ballpark statistics for a 4.5 minute audio file. We'll show you how many files your player can store depending on the quality of these files and capacity of the player:
Quality and size of an audio file/ player capacity 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 128 Kbps - 4.3 MB 120 240 475 950 1900 3800 192 Kbps - 6.48 MB 80 160 315 630 1260 2520 256 Kbps - 8.64 MB 60 120 235 470 940 1880 320 Kbps - 10.8 MB 45 95 190 380 760 1520 The speed at which a player can save data into its memory is not a key factor, but it's still important. The higher the speed, the faster you can copy files to memory. The usual speed is 2-5.5 MB/s for flash players and up to 15-20 MB/s for HDD players.
Prices for flash memory are constantly decreasing now. When you choose between identical players with different memory capacities, you should keep in mind that twice as much flash memory does not mean twice as expensive player, because the player itself also costs some money. So you should make up your mind whether to pay a little more for double memory capacity or save it.
8 bits = 1 byte
1,024 bytes = 1 Kilobyte (Kb).
1,024 Kb = 1 Megabyte (Mb).
1000 Mb = 1 Gigabyte (Gb).
Modern computers can store anywhere from 5 to 100 Gbs on their hard drives. Why would you need to worry about the file size of your digital audio with so much space available? Well, your computer needs a good chunk of its hard drive to store the operating system (Windows, Linux, etc.) and instructions for running things like your modem, your internet browser, and your email program. So space is often at a premium. You’ll see.
May 20, 2008 | Tascam DP01FX All-In-One Recording Package...
Olympus ws-110 no playback when connected to pc
ahh...that sounds like a player issue..open your settings on WMP and look to see that it's not on sample mode
Mar 25, 2008 | Audio Players & Recorders
Please help me for god sake, Hello,my name is nil.I brought a pair of headphones--name BEATS BY DR.DRE_.And after some days when i was walking in cold in a night ,i was hearing music in it..suddenly i...
what sample rate are you mp3 files make sure they are at least 128kbps . it could be being caused by a lower sampling rate. what happens is errors occur when the analogue signal is sampled and a digital level is encoded. If the rate is not fast enough bits of the sound are missed and when you replay the digitised mp3 file back into anologue ie sound you get errors.
http://www.sweetwater.com/insync/quantization-error/
Dec 29, 2014 | Audio Players & Recorders
Got the Tape2USB for christmas and cannot get it to successfully record to computer. Followed installation directions closely. When I want to record, I press [on Tape2USB] 'Play'. Then, I press [on MAC]...
I'm not familliar with this device but from the ERROR it spits out you seam to have a configuration problem, since it is a TAPE wich is 44 Khz SAMPLE RATE, check the sampling rate settings it might be to high or to low
Hope this helps!
Dec 31, 2010 | Grace Digital Tape 2 USB Dual Cassette...
WHEN I DOWN LOAD FILES TO MUSIC IT SAYS IT CANT SUPPORT THE FILE I HAVE HAD PROBLIMS WITH THIS UNIT SINCE I GOT IT.
go to your user manual. The format that the songs are in may not be supported. for example: if your player is a mp3 play the song have to be mp3 formate. it wont play WAV or AAC/MP4. looking at your manual found online here
http://www.p4c.philips.com/files/s/sa5285_37/sa5285_37_pss_aen.pdf
Compression format: MP3, WMA, AAC
•ID3 Tag support: Album title and artist name
•MP3 bit rates: 8-320 kbps and VBR
•WMA bit rates: 5-192 kbps VBR
•WMA sample rates: 8, 11.025, 16, 22.050, 32, 44.1, 48 kHz
•MP3 sample rates: 16, 32, 44.1, 48, 11.025, 22.050, 24, 8 kHz
•Digital Rights Management: Windows Media DRM for Portable Devices, Supports download & subscription music services
these are the formates supported. also make sure the music is in the proper folder
Feb 24, 2010 | Philips GoGear SA5285/37 Digital Media...
I have a WAV project that is 1.99 GB & when opened in Magix Audio Studio 10 Deluxe results in no sound & shows no graphics as if there is nothing there. Bit Rate=1441kbps Audio Sample Size=16 Bit;...
Thw bit rate is way too high!...
The other wav files you g=have are probably around 128kbps.... that files has 1441kbps.
You also reached the 2GB file size limit...
The other files are probably less than 4MB.
See if you can change the bit rate to 256kbps or so...
Hope this helps!
Sep 12, 2009 | Magix Audio Cleaning Lab 2005 for PC
Sampling rate
Jun 09, 2008 | Sirius STILETTO 100 MP3 Player
Sample rate error
Jun 07, 2008 | Sirius STILETTO 100 MP3 Player
Problem in video playing for kisen p83
Hi ,
It supports AVI, Mp4 and 3gp but you should convert the files only with the frequency specified in the manual only then it can be played i suppose. I have not yet tried it but that should be the solution.
Regards
A.Albruni
Jan 14, 2008 | Siemens M56 Earbud Hands Free Headset
Sirius STILETTO 100 MP3 Player Logo
100 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
