Question about Sharp Microwave Ovens
OUR R-530BS BS PURCHASED IN 1998 SERIAL # 115170 has a problem with the door. It will not open. I have lubricated it with WD 40 to no avail. I finally did get it to open with a sharp rap using the handle of a screw driver, and added more WD 40, but with out any improvement. Is it worth a trip to the repair shop? RICHARD GEIS 5222 MEADOW LAKE LANE HOUSTON, TEXAS 77056
    Genius:
  • 1,665 Answers
Have a look at link below
http://www.repairclinic.com/0047_6.asp
Posted on Jun 09, 2008
When I push the door latch button on the sharp R-530BS the door will not open
you must replace the door latch parts.test the door hooks can be broken.
go to www.repairclinic.com and buy it. God bless you
Sep 23, 2012 | Sharp R-530BS Microwave Oven
Have to slam door to get oven to operate
Try a) Lubricate the latches. I sprayed wd-40, you probably can use vegetable oil. Both sides, latch and receptor. Just doing this may fix your problem. (I have to admit I did part b first before trying this so I am not sure, but after doing this, it made my part b fix work even better)
b) Failing this, I found opening it up (t-20 torx screw driver) and tying a wire in the top hole, through the bottom latch body and fastening to a bottom hole of the microwave frame to force the mechanism to stay in place. You want to pull it towards the oven cavity. This will keep it from bending out of alignment. I found that it is only the bottom latch that has to catch for the microwave to sense the door is closed.
Mar 30, 2011 | Panasonic NNSN797S Microwave Oven
Door not opening properly, and keypad problem
The door is the simple bit. Loosen the hinge side of the door, (Underside hinge) and align the door hooks. The panel will require replacing as there is nothing to service on the keypad.
Dec 15, 2010 | Sharp R-530BS Microwave Oven
Will not operate. Does have power as the clock works.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
Since this is posted under R-530BS, I'll assume that's your model number.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
If that's not your model, feel free to contact me directly with your model number.
If you only need a switch, you can order a universal type here for $5 postpaid.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 29, 2010 | Sharp R-530BS Microwave Oven
How do I change the light bulb on my sharp R-530BS
You have to remove the shell. Screws are in the back and may require special tool (torx, security). Be certain to remove power and be very careful as the shell will have many sharp edges. The bulb is along the right side (as you face the oven opening). It is a specialty bulb you will have to order from an appliance parts house (or try e-bay).
Apr 15, 2010 | Sharp R-530BS Microwave Oven
Panasonic door handle (not push button) hard to open
I have had some success by taking WD-40 and lifting up on the hooks sticking out of the door and spray under the Bottom part of the hook into the door area. That lever guides through a metal slot that is part of the inner door. Sometimes that will help. I know you have to open the door but yanking it like that will eventually break off the metal huide part of the door and the inner door will have to be replaced.
Oct 19, 2017 | Panasonic Microwave Ovens
Sharp R 530BS-sensor cook doesn't work. It appears to work but
In all likelihood the mangnetron has failed, You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 31, 2010 | Sharp R-530BS Microwave Oven
SERVICE STICKER LEAVES MARK ON FRONT DOOR OF MICROWAVE
if you spray wd 40 or a light oil on a rag and work it into the glue this will break down the glue and make it easier to clean up.
Hope that helps...
Lbcoaster
Dec 29, 2008 | Sharp R-1610 Microwave Oven
DOOR ON MY 1998 R-530BS MICROWAVE OVEN WILL NOT OPEN.
There may be a grease buildup on the sides of the door open button.
Or there may be enough wear on the prong ends of the back side of the door open button or the face of the door open lever so that it is not pushing the latches up high enough to open the door.
The outer cover will need to be removed to diagnose and repair this.
You can find an exploded view by entering your model number here: http://www.searspartsdirect.com
On the exploded views, the door open lever is reference # 2-6 and the door open button is reference # 3-5.
The best place to order Sharp parts is Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 09, 2008 | Microwave Ovens
Sharp R-204CW microwave,won't start at all
try to slam the door and try again. sometimes the micro switch at the door are getting sticky and would not latch correctly. if it work, open the housing and spray some wd-40 on the door latches.
Feb 17, 2008 | Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
