Question about Panasonic Televison & Video
During a 'brown out' I played a dvd through my panasonic 36 PD 50 F crt tv for about 10 minutes. When I realised the set was struggling I shut down. Now the set won't start up. It responds to the remote but just makes a sound like it's trying to start up and failing.
    Genius:
  • 1,665 Answers
It seems like power supply circuit fault. Better take it to a service station to check it.
Posted on Jun 10, 2008
  • 4,234 Answers
Switch mode power supplies are sensitive to power levels. At this point there is a problem in the power supply. Most likely a number of capacitors have become defective. Without seeing the set and taking measurements inside, it will be difficult to determine the exact fault. I would suggest that you get a detailed repair estimate from a local repair shop. Post the results here and we should be able to guide you through the actual repair.
Keep us posted.
Dan
Posted on Jun 09, 2008
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
I have a 2001, Panasonic 27
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
May 16, 2012 | Televison & Video
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
LG 50" plasma will turn on then shut off shortly there after.
Unplug the power from the power outlet and let it sit for a few minutes. Then plug it back and it should work normally.
Apr 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
50' Philips tv issues
If you power up/down a bunch of times in a row (10-20 times)
Do you see a bright flash before it shuts down?
If so my guess is a faulty resistor and not the chip I mentioned earlier. I have seen a few posts on this site in regards to faulty resistors on the CRT board(s). If they go bad the set will shut down so that it does not damage the CRT.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
PANASONIC CT-36D31
check for dry joints around vertical chip, also dry joints in the horizontal stage will cause this also
Apr 15, 2008 | Panasonic CT-36D31 36" TV
Plays for a minute or two - then just shuts itself off
Mine will intermittently record only the first minute or two of a tv show I have queued up to regularly record. It seems to happen anywhere from every show to every 5-10.
Mar 04, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
No power
Try unplugging set from the wall for 5 minutes.  Plug back in and try to turn power on again.
Jan 08, 2008 | Panasonic CT-36D32 36" TV
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
