Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover™ SpinScrub™ SteamVac has a department for shampoo. My shampoo leaks out of the bottom and will not stay in for me to do my floors. Can this be fixed?
    President:
  • 1,673 Answers
Check the valve at the bottom of the tank, Check for cracks around where the valev is at the bottom of the tank, if cracked, replace the tank. With the tank off, can you see the rod in the handle move up and down when you squeeze the trigger. The part that the tank sits on is acalled a resevoir asm. it may have gone bad, or the seal is out of place.
Posted on Jun 10, 2008
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
I have a Hoover F5914-900 Steam Vac. I have used the upholstery/stair tool in the past with success. Today I installed the accessory tool , but when I turned the machine on, the fluid drained out the...
If fluid drains out through the bottom of the machine, rather than through the brushes, you most likely have a leak in the quick disconnect valve. ( part # 43523004, msrp $4.99 ) This is the small valve that the end of the hose connector snaps on to. If this is the problem, it will also leak when doing normal rug shampooing. This is a somewhat common problem with this machine. The valve will need replacement.
Jun 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Where is the STEAM in the Hover SteamVac F5914-900??
There is none kind of false advertising it does not even heat the water. You just put hot water and shampoo and go.
Dec 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub won't stay upright or collect water
(1) Upright: Sounds like the tab on the lower handle that the handel release latches to has broken off. The machine is fully functional without it otherwise.
(2) Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac F5826-900 leaks from bottom wheni put tank on ple
You may need to replace the gasket.if that dont work replace the whole tank
Aug 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAMVAC CLEAN SURGE
The tank lid is not securely shut. Or you have stopped up machine full of carpet lint and dirt. Take it apart starting with the lid and make sure its locked down good if that isnt it ..clean out your machine.
Oct 18, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Water spray
Are the brushes turning while you are shampooing? If not then this could be the problem. The turbine is what turns the brushes, it may have gone bad.
Mar 01, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
229 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
