LG Flatron monitor issues
Hi- i have an issue with our monitor shutting off after a few seconds........it will flash the screen, then go blank....please help
  • 1 more comment
  • ellenrose Jul 02, 2008
    I have a Philips 170B4 monitor. It flashes on the goes blank when starting the computer or turning the monitor power off and on. The image doesn't stay on the screen long enough to use the monitor's on-screen menu to reset the monitor and there doesn't seem to be a way to reset it from another computer. All the connections are solid. Any ideas? The posted solution doesn't help.
  • Anonymous Dec 18, 2008
    I just bought an HP LP1965 (used) and it does the same thing.
    I have tried two computers, a third seperate graphics card, both of the monitors DVI inputs and two different cables, all with the same result.
    The screen comes up for about two seconds then drops out. If I press the 'auto' button, it comes back on for another 2 seconds then drops out again.
    Very annoying so any help (other than sending it back to HP) would be welcome :)
  • larrysfl May 10, 2009
    I have the exact same problem on two Dell LCD monitors - a 19" and a 21". Both went out within a day of each other. Changed computers, video cards, changed from DVI to Analogue - nothing fixes it. Probably FUBAR'd.
  • 31 Answers
If your using different graphics card or maybe use the onboard and check the power connector and wire throught the graphics if it is not loose.btw I have the same monitor as yours.
Posted on Jun 10, 2008
Lg flatron L1919S is blinking when I connected it as a second monitor
If it works as your first monitor, then it is either the cable/connection issue or the graphics software is not seeing it correctly or the second graphics card is not in correct or a combination somewhere.
You will need to do a bit of fault analysis to determine what is causing the issue.
Dec 30, 2013 | LG Flatron 915FT 19" CRT Monitor
My monitor slows down
Sounds like an issue with you PC not the monitor.
Try updating your display/graphics card drivers.
Welly250
Jul 02, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Mr Pateman
This is more likely an issue with you video card than your monitor, do all the monitors you have tested operate at the same resolution and refresh rate? It sounds like the LG monitor is running at a higher resolution and refresh rate which is causing addition load to be placed on your video card causing it to crash
May 07, 2017 | LG 22" FLATRON LCD Monitor
Screen comes n normally for a few seconds then
i got the same problem, i tried warming with a phon the inverter card and it works until it became cold... it can be a soldjering, but i still can't resolve the issue...
Jan 17, 2010 | LG Flatron L1511S 15" Flat Panel LCD...
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor won't light up. Only just for a second or two.
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Aug 05, 2008 | LG Flatron L1515S 15" LCD Monitor
LG L1715S TFT power issue
Change out C202- 680 uF 25 Volt electrolytic capacitor. Replace with 25 volt or higher. Observe proper polarity when replacing cap: (-) goes to the side with the black mark, check old cap before removing it to see. I just fixed the same monitor today.
Dec 04, 2007 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
817 people viewed this question
David Payne
David Payne
