46 sam dlp problem
Nov 2004 bought a 46 dlp .the issue I have is it turns on picture is still bright.It shuts off after 2 min 10 min 30 sec it varies.sometimes it stays on(rarley).alson middle bottom looks like the pic is brighter in darker situations.sometimes when it shuts down i will have blinking lights in front 20% of the time it shuts down and thats it.
please help We have a problem with our 46# DLP Samsung in that it just randomly cuts off. When you cut it back on it will run for even less time. Finally it get t obe so often you cut it off for hours. We have repalced the tube twice so that is not the issue. We have it in a cabinet and we have aded a fan for circulation. We do not know what to do next. The TV repair perosn could not get it to tunr off in their shop. Any thoughts would be appreciated.
    Genius:
  • 2,028 Answers
After reading sevral mixed reviews, I might have to say it's time for a new one. The reviews I read are either, they love it, no problems, or it's a pain, problems starting about a year after purchase. One thing you can try, if you're not ready to give up on it, is a professional calibration.
Posted on Jun 17, 2008
  • 1,879 Answers
Tried it running outside the cabinet ?
    Master:
  • 555 Answers
It sounds like an overheating problem.
Posted on Jun 09, 2008
  • 796 Answers
Shut down with increased brightness: most likely cause is loose wire on pin # 2 on P406 (ABL) located at bottom left of power supply board. Press wire into plug portion for tighter connection.
Hl-s4266w samsung no picture or sound timer flashes and then shut
replace Both of your STK ICs they are big black ics will have part number on them CK 2 resisitors 2.7ohms sometimes they will be bad also they are in same circuit as STKs STK394-020 040s call Mats for parts 1-800-628-1118
Sep 21, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
46 sam dlp problem
This is pure conjecture but I think the cooling fan has failed or is running slow.
Check to see if it can still be heard.
This system seems to be a bit weak on reliability.
Mar 30, 2008 | Televison & Video
No Action from a HLN467W
I would wait to see if it happens again.
Feb 26, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
