Question about Motorola Mobility H700 Wireless Headset
Purple light One day i went to charge my headset and everything was fine. When it finished charging i went to reconnect it to my phone and a purple light came on. Now my headset stays purple and it won't connect to my phone. (by the way, I have the LG Ruomr.)
  • 1 more comment
  • Anonymous Jun 19, 2008
    purple light after charging
  • Anonymous Jun 24, 2008
    Same issue: completely charged my earpiece and now it says it's connected but it has a purple light on and it won't transfer from the phone to the bluetooth. Also have an LG Rumor. Tried canceling and reconnecting with the bluetooth but nothing is working.
  • pjcoleman195 Jul 30, 2008
    I charge my phone and it goes green then I disconnect to use it and it blink blue once then goes to purple. However when I plug it back to the charger it goes green.
    Sergeant:
  • 287 Answers
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Posted on Jul 03, 2008
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
My Plantronics 665 Bluetooth headset went into a locked weird mode (no lights, no pairing, no turn off) The lights enabling feature is not working as it should. I doesn't turn off when keeping the...
Try letting the power on the headset deplete and then try recharging the headset. Not sure why you are having a problem with the headset not powering down, but that will generally take care of it. Sometimes if you don't turn off the phone it can lock the link between the phone and headset and in which case the headset will not turn off.
Everything I read on it indicates that the only way to reset it is to let the battery completely die, which takes up to 7 days if you have a full charge on it. Put it in a ziplock bag and put it in the freezer and the battery should drain overnight. Charge it back up and it should work fine again! If you try this, squeeze as much air out of the bag before closing, so there's as little moisture as possible.
Good luck from Headsets Direct!
Jul 01, 2011 | Plantronics In-The-Ear Discovery 665...
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
Solid Purple Light on Plantronics 220
Explorer 230 went into solid blue light the second time I used it. Fixed mine by letting the headset go completely dead and re-charged and it appears to work fine now.
Oct 09, 2008 | Plantronics Explorer 220 Bluetooth Headset...
PLANTRONICS VHB 300 PURPLE LIGHT
HI
I SOLVED THE PROBLEM
LET THE HEADSET RUN DOWN, THEN PUT IT ON CHARGE,RED CHARGING LIGHT CAME ,CHARGED FOR 2 HOURS, THEN PAIRED TO 6300, WORKING OK.
JOHN
Sep 06, 2008 | Plantronics Explorer 320 Wireless Headset
H700 automatically disconnects though fully charged
I had the same problem. It does seem to be related to the battery. The solution--in my case--was to recharge the headset until the light turned green again and then flip it open and it hooked up again.
Mar 13, 2008 | Motorola Mobility H700 Wireless Headset
Connected then Disconnected!!!
that could mean your headset is not charging. make sure the light is doing what it is supposed to when charging. you probably have a defective charger. happened to me. you could try pairing it with another phone to see how long it lasts. I found the Moto HS850 to be the only good, reliable one.
Jul 09, 2007 | Motorola Mobility H500 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
528 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
