Question about Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)
Hard Disk Failure
Dear All,
I have a IDE hard drive; recently the windows alert me that there are some bad sectors in your hard drive and you need to fix the problem.
I went and buy a new hard drive to replace and copy all information from the older to the newer.
Unfortunately after starting the PC I saw that the computer did not recognize my OLD storage.
I hear some noise for awhile after starting the computer from inside of hard and the noise stops.
Somebody offer me to recover my data by paying considerable money payment.
Has somebody encountered with similar problem?
Could you guide me how can I handle this problem probably using software solutions?
  • 32 Answers
Here are some tips.
1. Repalce the old one with new, install operating system, then connect the old one as a slave. Most of the time the OS will recognize the slave drive and you can copy data. Unfortunately this method will not allow you to copy your installed programs, only data and other stuff and is more time consuming.
2. Here's the old man's trick. Take out the failed disk, wrap it nicely with a few layers of plastic, so that moisture or water will not go inside and place it in the freezer overnight. Google this for more info, as this trick has helped a lot of people to recover their data.
There are more you can do, but since the drive is not booting up, these are your two main options.
3. Another one is to get an external enclosure and put the old one inside that and connect to a working pc and copy the data, but this requires either you do the first option or have another PC AND the external enclosure.
And remember, you may have to do chkdsk or use some third party programs, if the disk is corrupted beyond a level.
I would recommend "spinrite", a free data recovery program.
Good Luck & let us know if you need more info.
Posted on Jun 10, 2008
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
I have a imminent failure and when I press F1 then I start installing Windows the system doesn't detect my HDD. I have a bad sectors and I know it. But I can't solve it. Can you tell me more information...
The motherboard is quering the 'S.M.A.R.T.' status of the disk-drive,
and the disk-drive is reporting that it is about to "fail".
So, your motherboard is showing that "Imminent failure -- press F1 to ignore this alert" message.
Take your computer to a qualified technician, to see if it is "too late" to recover any files from your disk-drive, and/or to install a new disk-drive, and to install Windows.
Nov 09, 2010 | Hitachi 60GB Travelstar 5K160 Ultra...
Hp invent with windows xp pro after restoring to an earlier date says windows cannot start driver corruppted?Did system Diagnostics hard disk test failed test 2 (Comprehensive)...Error: Read Failure
Restoring to an eariler date cannot fix this problem.
If the hard disk diagnostics failed, this could indicate the hard drive is about to fail. The hard disk platter/s most likely has some bad clusters and if any files are located on these bad clusters then you would get a read failure. The number of bad clusters will increase and cause further problems.
Run chkdsk to lock out these bad clusters but this is a temperoary solution and the computer may not be able to relocate the data from the bad sectors to a good sectors.
The fix is to backup your data as soon as possible, then replace the hard drive with a new hard drive and re-install Windows and the Compaq's device drivers.
Jul 22, 2010 | HP Compaq 6735s Notebook
How can i remove bad sectors from my hard disk?????
You can not remove bad sectors from hard drives. Bad sectors are parts of the disk that become unreadable / unwriteable. Hard drives made in recent years simply stop using that part of the drive.
Apr 07, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
Seagate Barracuda 7200.7 ST380011A "a disk read error occured"
Might be a damaged sector. Otherwise i would think you (by accident) created a seperate partition on your C:\ (? main) HD. The cause of damage can be many things, certain types of certain brands or more sensitive in how fast these sectors get damaged. But you can at least try to repair them with the disk repair utility in Win XP, called ChkDsk ("check disk"). However, what may end up happening is that ChkDsk will mark the sector as bad (instead of attempting to recover any information) and your hard drive will no longer 'hover' over top of that area of the drive, making it impossible to recover any data on the sector. Maybe try to google for (free) BETTER third party software for this first. So what caused it is hard to discover after it happened, but you can try to repair it.
Nov 05, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Using a Sata Drive with an IDE cable
Depending on how old your system is, even though your current drive is IDE, there might still be SATA support on the motherboard. Look in your manual and find out if it has any SATA connectors. If not, you need to continue using IDE unless you want to purchase a PCI card with SATA connectors on it.
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Smartdisk - Peripherals Computers & Internet Experts
Arora Singh
Arora Singh
Level 1 Expert
Becky Willson
Becky Willson
Level 1 Expert
Are you a Smartdisk - Peripherals Computer and Internet Expert? Answer questions, earn points and help others
