Question about RCA TruFlat 27F520T 27" TV
RCA TruFlat Tv problem
My t.v. has a one inch black strip across the top of the picture. The whole pic seems to be down an inch. Regular t.v. is showing bottom of t.v. as cut off.
  • wilband_66 May 22, 2009
    ok ya i have the exact same problem and im sorry to say but your advice did not help at all, this is because i could not understand a word you said, i just want to know if i can fix this in the settings or do have to buy some crazy contraption...
  • 85 Answers
YOUR TV HAS A RETRACE PROBLEM,FIND THE CAPACITOR 35V/100uf,1V/10uf AND COLDSOLDER FIRST THE MAINBOARD BEFORE YOU REPLACE THE COMPONENTS.
Posted on Jun 12, 2008
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
On my RCA truflat tv there are solid white horizontal lines going across the top 5 inches of the screen? Do i need to get it repaired or is it a simple problem?
Hello
Your TVs vertical output section has the trouble. Electrolytic capacitors in that section, 8 numbers the most, should be replaced with new capacitors. Iit won't cost more. OK.
Jun 12, 2011 | RCA TruFlat 27F520T 27" TV
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
Black strip across the top of the picture
I can tell you exactly what is happening. This is probably either happening when you are taking a photo with a flash? The maximum flash sync your camera has is 1/125 or 1/60 of a second. If you set your shutter speed faster than that, you shutter closes too slow and creates that black strip. Put the shutter speed to 1/60 or slower and see if that happens. If you have a long lens on the camera, you have to have the shutter speed either equal or less than the focal length to shutter. 50mm lens=1/50 a second without a flash. Otherwise you could have a bent or broken shutter curtain blade. Maybe someone stuck their finger in there.
http://www.cameradr.com/
He can fix it if you blades are broken.
Jan 02, 2009 | Nikon N75 35mm SLR Camera
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
Top inch and a half of tv picture cut off.
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need.  See my next post in a few minutes.
Oct 16, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Truflat 27 inch rca
vertical capacitors beside of vertical ic no other problem the capacitors only
Aug 15, 2007 | RCA TruFlat 27F520T 27" TV
Large Black Strip across the bottom of the (TV Cable) Picture
This happened to me too and i fixed mine by going into settings and for some reason my subtitles were turned on. turn it off and it should fix it.
Jan 14, 2007 | Hyundai ImageQuest HQL320WR 32 in....
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
RCA TruFlat  27F520T 27" TV Logo
182 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
