Question about Kenmore 19233 Computerized Sewing Machine
Machine will not run
Went to use machine and will not run--displays "stop for safety purposes"--I have rethread the machine, reinserted the bobbin, have checked for lint in bobbin holder and feed dog--none--I cannot move needle manually nor with foot pedal.
When I have this problem, I turn the knob back and forth (gently) to try to get the needle to release and lift. I get this error message when the needle has shifted (either in the fabric or from using the machine alot at the needle placement shifts).
check your needle, it probably has shifted a bit.
Posted on Jun 10, 2008
Singer 7442 won't stitch at all. It picks up the bobbin thread nicely, but after that won't stitch at all. Any suggestions?
Sound like one or the other of the threads is stuck. Completely un- thread your machine and remove the bobbin. See if the needle moves freely with the machine unthreaded. If it does, carefully rethread the machine and reinsert the bobbin, making sure the bobbin thread is feeding the correct direction. Let us know what happens.
Oct 23, 2016 | Singer 7442 Mechanical Sewing Machine
I have an error E4 on my Singer Sewing Machine. I have searched the manual and cannot find anything on this error. I have only used my machine a few times. It is brand new.
if it's still under warrenty I suggest taking the machine back.
try changing the needle
try turning the bobbin the opposite direction
if you have a front or side loading bobbin case try reinserting
the bobbin case back in the machine
or it could be the motherboard has gone bad, or the foot pedal
Dec 01, 2012 | Singer 7258 Sewing Machine
How do I fix error E4 whe no thread is tangled?
rethread the machine top and bobbin
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
also possible that something has gone wrong with the computer
part of the sewing machine.
Nov 30, 2012 | Sewing Machines
I rethreaded bobbin fine but I can not get into bobbin area. Activa 135. The part that has the pole on it to load bobbin will not stay stable. Parts keep falling out of machine. Help
if the hook & hook race are not in the machine stationary then the machine needs to be check to find out why there not staying in there position
& since the machine hasn't been used in years it needs to be serviced
Apr 03, 2012 | Sewing Machines
My 6003 Elna machine stop and says stop for safety purposes How do I get it unlock from that It wont do anything
This is usually what happens if the bobbin case gets dislodged, its just held in place by a magnet but if you have a jam up, often gets moved out of position. Remove top metal plate, take out bobbin, and have a look at the bobbin case, should be two metal markers or red dotsmfront side that align. Lift the case out by grasping edge and lifting up and towards you, clean underneath with the little brush, remove any jammed up threads, then return case to position, aligning the marks.
Feb 24, 2012 | Elna Sewing Machines
Elma Pro Quilting Queen, I keep getting loops on the bottom. I have rethreaded, reinserted the bobbin and it keeps doing it.
change the needle
clean under the needle plate where the feed dogs are for lint
also clean in bobbin area for lint & loose threads
rethread the machine make sure to get every thread guide
check the thread tension usually 3 or 4
Nov 22, 2010 | Elna 7200 Computerized Sewing Machine
Have been given an old frister rossmann 402 machine with no maual so i cant work out why it sews some stitches and becomes hooked up underneath by loopy threads
change the needle
rethread the top thread make sure the thread doesn't come off the thread take up lever
check the bobbin area for lint or loose threads
also rethread the bobbin in the bobbin case & reinsert it
also check the top thread tension try 3 or 4
Nov 04, 2010 | Sewing Machines
My sewing machine wont make a stich it just keeps making little holes
Take out bobbin and reinsert it according to manual. Also completely rethread the machine.
Aug 13, 2010 | Kenmore 15218 Mechanical Sewing Machine
Tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Feb 27, 2009 | Brother ES2000 Computerized Sewing Machine
Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
sewman7
May 22, 2008 | Janome Memory Craft 5700
Kenmore 19233 Computerized Sewing Machine Logo
206 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
