Question about OKI B4250 Led Printer
Yellow light all the way to the right just flashes?
I used the status monitor and it said Connection problem, either printer is turned off or the cable is not hooked up.Obviously it is hooked up because my computer tells me its ready and online.Can someone please help me.
  • okidata4250 Jun 09, 2008
    Oh yea it will not print.
Delete everything printer related. ie. printer, status monitor, and try to print a test page via the button, I think you have to hold it down for ten seconds. I could be wrong though.
Posted on Jul 30, 2008
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Flashing lights green and yellow 10x and the printer head is stuck to the right
10 times
B200 VH monitor error.
You will have to replace the printer.
Nov 01, 2013 | Canon PIXMA iP3300 InkJet Photo Printer
Canon ip 7240 i used refill ciss but 4 flash
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. When a printer flashes 4 times this is a sign that an ink tank is not installed correctly or that the cartridge will need to be replaced as it is low on ink. As you are using a CISS the cartridges will always have ink in them. To bypass this error all you will need to do is press and hold the RESUME button on the printer for 10 seconds and this will turn off the cartridges ink status monitor and allow you to continue printing.
Canon Error Codes
I hope I was of help to you
Oct 30, 2013 | Office Equipment & Supplies
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
How to find ink levels in hp932c printer
Print Cartridge Status The Print Cartridge Status Light flashes when one or both of your print cartridges are low on ink, improperly installed, or malfunctioning. It will also flash if you are trying to use the wrong print cartridge type. If the problem is low ink, the light will stop flashing when you open the top cover. For any other print cartridge-related problem, the Print Cartridge Status Light will continue to flash. To check the status of your print cartridges, open the printer's top cover. The yellow arrow on the print cartridge cradle aligns with one of five Print Cartridge Status icons.
Jan 08, 2011 | HP DeskJet 932c InkJet Printer
Red lights flashing. I dont think the ink is out and i did try taking them out following the instructions and put the same ones back in but it still won't print and the light is still flashing, will it...
Printer wouldn't print if red light flashing. Check status monitor for detail? Are some ink not recognized? Do replacement procedure from status monitor on "How to...". Unplug all ink tank. Plug only one ink tank . See status monitor. Is ink tank recognized. repeat procedure, and add ink tank 1 by 1. How about status monitor then?
Jul 09, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Alarm button Flashing, will not perform any function
Turn your printer on. On your computer, go to:
Start
Printers and Faxes (or Control Panel - Printers & faxes)
right click on your printer icon
click on "Printing Preferences"
in the dialog box, click on "Maintenance" tab
click on "View Printer Status"
in the dialog box, click on "Options"
then deselect the "Enable Status Monitor" option (remove check mark)
When the alarm light on the printer blinks and the printer won't do anything not even scan, you can press the reset button (on the printer) for 10 seconds and then, while holding the Reset button down, you simultaneously press the OK button (on the printer) for a few more seconds. For some reason, I sometimes need to do it several times before the alarm light goes off but so far, it always unblocked the printer in the end.
At that point, do the "Enable Status Monitor" as explained above. (put check mark back)
When you need to check the levels, you can either look at the cartridges physically or enable the status monitor (if you are still using 'legal' cartridges in one or more slots).
Google for "Chip resetter for MP530" or go on Ebay for this product.
Jan 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Status monitor for Konica Minolta 2400w
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
Aug 02, 2008 | Konica Minolta magicolor 2400 Laser...
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
OKI B4250 Led Printer Logo
855 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
