Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Drum won't go back and forth on wash cycle
I performed test on electronic control module-ok. i replaced wash timer because machine working intermittent and would stop at rinse cycle.I would advance timer one click and washer would carry on till spin cycle and then I would find it necessary to advance timer to get it to spin. now washer won't wash-fills with water and sits there. If i advance timer it will pump water out fill and sometimes go into spin cycle. I have been nursing this puppy on for a year trying, testing, coaxing it to perform and now i can't see adding more money to buy a control module. The machine has worked well for us for 5 years and now i'm stuck on what to do next. The international answer is to buy a new machine-Thanks ahead of time for any suggestions.
  • 1 more comment
  • andy8584 Jun 09, 2008
    yes i have checked the motor, and the tub does spin, and does go back and forth on the dry cycle
    I haven't checked the door latch sensor which is on the trouble shooting check list but it sure wouldn't spin if the door latch wasn't working.
    Yes the drive motor is ok
    Brigadier General:
  • 3,614 Answers
Have you done checking the drive motor...?
Posted on Jun 09, 2008
  • 1 more comment
  • micromaster
    micromaster Jun 09, 2008
    is the tub still spin, or it has been stuck there...?
  • micromaster
    what did you find out.. is the drive motor was still okay..?
  • micromaster
    also check fo any loosen drive belt
    Master:
  • 555 Answers
Try checking the door latch and sensor.
Zanussi FJ1214 Washing Machine won't agitate but spins
Sounds like gearbox or check if a belt has came off or slipping underneath.
Nov 01, 2014 | Zanussi Washing Machines
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
I have a Miele W1918 washer that is getting stuck in the main wash cycle.
All washing machines have a pressure switch , it is a rubber tube leading into the outer drum and up to the switch, located up on the frame top rail under the lid, if this tube becomes blocked with dried detergent suds it wont function, gently pull of the rubber tube from the switch and suck and blow through if you can or push a piece of flexible electric wire through it then blow it again and reconnect and test.
DONT pull the tube out of the drum or you could have a leak, that\'s why I said GENTLY.
Good luck
Mar 11, 2014 | Miele Washing Machines
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
We have an Indesit washer dryer WDG1295. When switching on, it fills with water, hums away as though it is working (including draining) but the drum doesn't turn. The belt looks fine, and if you move the...
Immediate thought was the belt but you already checked that. Reading your message, you seem to be indicating the washer goes through the wash cycle and does everything except turn the drum, i.e. it fills and drains and the timer control knob advances as you would expect. This machine has an electro-mechanical timer rather than electronic, so if it advances through the program correctly, I would exclude this from my initial checks, but I'd still come back to it later.
Washing machines aren't that complicated, so if all of the above is true, the obvious assumption would be the drive motor. You've obviously opened up the machine to check the belt, so have you tested the motor with an ohm / multi-meter?
Please confirm the correct operation of the timer and whether you have tested the motor and I will try to assist you further. I check messages regularly, so if you post back here I should reply fairly quickly. Make sure you reply from within this page - don't post a new help request!
Regards,
BElectric
Nov 27, 2010 | Indesit Washing Machines
Washer agitates so vigorously water sloshes out of the overflow tube on large,extra large and super cycles. Tub slams back an forth on agitate cycle is this normal?
sounds like to much water check diaphram switch this controls the amont of water taken in this is not normal operation also check that the drum dampers are working ok or have not come adrift, when empty if you was to push the drum back and forth you should feel quite a bit of resistance if it moves easly then i would check the dampers
Jan 16, 2010 | GE Profile WPRE6100G Top Load Washer
Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Jun 18, 2009 | Kenmore Washing Machines
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
96 people viewed this question
Top Equator Washing Machines Experts
isaac johny
isaac johny
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
