Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Router question Recently moved and no longer have DSL. Have hard line cable internet, but I'm not sure how to hook up the wireless router. Have a Netgear 824v2, can you help?
  • 4 Answers
Step1: Physical connections.
In netgear router you can find 4 ports together and one standalone port.
connect the computer to any one of the 4 ports.
connect the modem to the stand alone port.
turn on the modem and the router.
Step2:check the light status on the router.
Step3:check the ip address.
click on start on computer.
go to run and typr in CMD and say ok.
black window pops up.on that type in ipconfig and press enter.
it will shows up the ip address, Subnet mask and default gateway.make a note of default gateway.
step4:open up the browser page and type in the default gateway address and press enter.
step5:then it prompt you to enter the user name and password . user name is admin and password is the word password in lower case and say ok.
step6:you can find small blue screen in the left hand side of the router page.
In that very first option is "set up wizard".click on that.
you will have a question, "smart set up wizard can detect the type of connection you have".. selcect "yes" and say "next".
wait for a while .. it will give u mess , "Dynamic ip DHCP detected".
step7: from the left side blue screen, click on basic settings, there u have a question, "does ur internet connection require a log in". say no and go to the bottom of the screen you can find the option "router mac address". in that select the second option "use computer mac address and click on apply.
Step8:from blue screen in left, click on "router status". check under "internet port" is there any ip address. if there, check are u able to go online.
step9: if there is no ip address under internet port, unplug the power cable from the modem, wait for 5 secs and plug it back.
then unplug the power cable from the router and wait for 5 secs and plug it back.
step 10:check u able to go online.
hpoe this hepls u :-)
Posted on Jun 13, 2008
    Problem Solver:
  • 6 Answers
If your talking about configuring it. Go to http://192.168.1.1 that is your routers configuration page. (By default)
Posted on Jun 09, 2008
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Is there a way to hook into my dsl internet to get wifi
Does your DSL not have a wireless router? If not, you can certainly get one for cheap...walmart has Belkin/Netgear/ASUS wireless routers for about $40...the instructions are pretty straight-forward. It's a cheap and easy. let me know if you need assistance.
http://www.walmart.com/search/search-ng.do?search_constraint=0&ic=48_0&search_query=Router
Jul 19, 2010 | Dell Dimension 4700 PC Desktop
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Dec 01, 2008 | Lands Phones
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Problem with belkin router
assuming you are connecting wirelessly; you may have to check that the router is allocating ip addresses automatically to your pc's. connect one of your pc's to the router via the RJ45 network cable that was supplied and not wirelessly and type 192.168.2.1 in your internet browser, this will take you into the routers setup menu. Look for a menu refering to 'DHCP' and make sure that this is enabled, then look for the channel number that the router is using (normally 6 or 11) and make a note as if you are still experiencing signal loss, you can get back into the router and change to any channel between these numbers incase you are getting appliances interfering with the signal, save and exit from the router menu. disconnect the cable then go to control panel, network connections and right click on the connection you are using whether it is wired or wireles and click on properties. Look for the line TCP/IP and again click on the line and select properties, then make sure automatically obtain ip address is selected, ok and close window. Restart the pc's and you should have a connection.
Jul 08, 2007 | Belkin (F6D3230-4) Router (F6D32304)
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
