Question about KONFTEL 100 Audio Conference
Yamaha kt100 kart
The karts fuel runs through a fuel line, which the fuel is gravity feed into the engine but, the fuel doesnt seem to run through the line, what could cause the fuel not to be gravitated towards the engine?
I've never seen a KT100 before, but i've worked with similar engines.
The fuel isn't gravity fed. It uses a pulse pump system using diaphragms in the carburettor to sort of "**** and blow" the fuel using pressure impulses and valves to stop the fuel going backwards.
The first place you should look is if there is a short pipe from the crankcase to the carb so that the pressure pulses from the case can move the diaphragms. You should be able to see this from some pics on google images. If thats all ok, you should check if the carb is perfectly clean. If its still giving you problems, change the diaphragms in the carb. You should be able to get a replacement rebuild kit from a dealer.
Posted on Jan 06, 2009
You need to pump the fuel into the engine the first time you start it. Choke the engine by putting your hand over the airbox holes while you turn the engine over. You should see the fuel moving towards the carby. Kaep doing this until the engine starts and once it starts remove your hand from the airbox.
Posted on Aug 31, 2010
Can i ?
and how 2 fix the black box igntion on a kt 100j engine thanks luke
Posted on Jul 02, 2010
The Karts fuel is not gravity feed, it is actualy pumped in to the engine by the carb. . Sounds like you need to rebuild the carb.
Regards, Mike
Posted on Jan 12, 2009
5.0hp tecumseh power sport wont start
you have to take the bowl off the carb and see if the Jets are clogged.
How long did it run before you shut it off?
Oct 04, 2012 | Garden
Go kart doesnt run anymore wat could the problem be
Wire connection seems to be the problem with any electric dependent vehicles of that sort. They are usually cheap so the wireing is cheap as well. Check to see if there is any loose wires or even some cuts in the wire. Repair them if so. If not that...make sure anything that likes too dirty than what you think it should be...clean it off with a can of compressed air (don't put water on that sort of stuff). Keep checking around the kart and check for anything out of the ordinary and work from there.
Hope this helps ^_^
Jul 19, 2011 | Razor 300001-SL Ground Force Go Kart
BRIGGS AND STRATTON MODEL # 91202 MANUAL TO FIX...DISCONTINUES RUNNING STARTS THEN IMMEDIATELY STOPS .INSTALLED NEW PLUG. NO CHANGE . GAS SUPPLY? HOW FIX
diaghram on the side of the carb facing towards muffler 4 screws when you take them out be careful there is a diaghram you replace, spring saver, and spring make sure they go back in the same order, whenever these engines or any horizontal with pulsa jet carb doesnt start it is usually because of diaghram I ran alcohol go karts and you have to drain the alcohol after you are done running karts and they will eat them up quicker than normal gasoline
Jun 23, 2011 | Sears Home Security
Manco cart tecumseh engine runs but has no power
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 14, 2017 | Garden
Starting a yamaha kt 100 go kart engine
just bought this go kart , the guy said it was a yamaha kt 100 2t 2 stoke but i have no clue about this motor , is it a good one
May 27, 2009 | KONFTEL 100 Audio Conference
Carbie tuning
Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Don't be chincy with the spray. You probably have a varnish buildup that is stubborn to remove. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks!
Mar 29, 2009 | 2003 Yamaha YZ 125
ENGINE RUNS BUT NO POWER
IT COULD BE MORE THAN ONE THING,,, FIRST CHECK COMPRESSION, IF IT HAS LESS THAT 80 lbs THAT IT,,, PUT IN NEW RIGS,, IF IT HAS COMPRESSION, THE TAIL PIPE COULD BE STOPED UP,, IF NOT,,, 2 STROKE ENGINE'S HAVR REEVE PLATES, THEY COULD BE BAD,, REPLACE THEM,,, THE CARBERATOR COULD BE IT IF ALL THE OTHER THINGS ARE GOOD, MY BEST GUSS IS,,,,,,IT NEEDS RINGS,, LARRYFRANKUM6780@SBCGLOBAL.NET LET ME KNOW,,,
Dec 10, 2008 | KONFTEL 100 Audio Conference
KONFTEL 100 Audio Conference Logo
1,856 people viewed this question
Top KONFTEL Lands Phones Experts
Are you a KONFTEL Lands Phone Expert? Answer questions, earn points and help others
