Question about Mitsubishi WS-55711 55" Rear Projection Television
Ws-48511 I have the mitsubishi ws-48511, I doesnt power up. It does its intial flash of the green light when plugged in. I you go to turn it on the green light will flash then theres a click inside and nothing happens. I did the self diagnostic on the tv and it reads 22 for short protect, I found 2 fuses bad f9a04 and f9a05, im ordering these, but what would cause the fuses to blow?
3 Suggested Answers
  • 41 Answers
SOURCE: where to buy F9A04 and F9A05 fuses (Mitsubishi)
Those are called "pico fuses" and marked value is on the board, probably 5 amp. You will want to replace the STK IC's mounted to the large heat sink also. Any TV repair shop should be able to help or supply the parts you need (policy permitting).
Posted on Dec 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2009
Relmdrifter
  • 6 Answers
SOURCE: Mitsubishi WS-65807 blinks '22'
I replaced the pico fuses and the convergence IC's. fuses poped right away code 22 . Further inspection of the board showed the coolant had leaked out of the center projector and fried the board. Not willing to pay $300. Passed it on to someone else
Posted on Nov 18, 2009
Tip
Mitsubishi WS-55711 Manual Download
Download Mitsubishi WS-48511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55711 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-55711 VChip Password
Bypass Mitsubishi WS-55711 Front Lock
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi WD-48511 Flashing green power light
The green light should only blink if set has been unplugged---upon plugging it back it will blink for about 70 seconds and go out----this is the set booting up and is normal.
At that point you should be able to turn the set on-----what happens when you try?
Mar 17, 2012 | Mitsubishi WD Televison & Video
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Tip
Bypass Mitsubishi WS-48511 Front Lock
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Mitsubishi WS-B55 Manual Download
on May 03, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Mitsubishi WS-48511 Manual Download
Mitsubishi WS-48511 Device Screen Will Not Go Away
David,
Let's start with unplugging the set from the wall power for 15 minutes. This will hard reset the micro... While that's unplugged inspect the buttons on the front panel of the Tv to see that none are stuck in a pushed-in condition. Plug the unit back in, power it up and if all works okay you're back in business... If not, let try a keyboard unlock. Press and hold the "menu" button on the front panel for 10 seconds. You won't see any on-screen changes but then try to select an input from the buttons on the front of the Tv.
After you've done these drop me a note and if we haven't solved it will try some other things..
Bill
Dec 02, 2007 | Mitsubishi WS48511 48" Rear Projection...
Tip
Have you misplaced your Mitsubishi WS-48511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-48511 HDTV Users Guide?
I hope that helps.
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-55711 55" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
