Question about Vivitar ViviCam 3785 Digital Camera
Pictures cant be viewed says no image-then wont take pics says card full?
Im not sure what happened, but when I turn on my camera it says no Image when I try to view the pictures, then when I try to take a picture it says Card is full. I really dont want to lose these photos what do I do to get them off??
  • 89 Answers
Try the memory card in a card reader and plug it into a computer. see if the computer can detect the card and the contents in it. if it does detect it then that means there is a problem with the camera not recognizing the card or files in it. if it does not detect it in the computer that means the memory card of the camera is the one having problems.
Posted on Aug 25, 2008
When viewing pictures on playback some turn black and no image is available? Does anyone know why this happens? Thanks.
Hello SugarAlmonds,
If by that you mean some pictures are OK and some are blank/no image available... that usually happens when the pictures have been edited (could be accidentally by rotating it while viewing it) in a computer OR the pictures are not properly deleted. So, when viewing pictures from your camera to your computer, it is always better to copy all of them first to your computer then you can view/edit the copied files.
To correct the problem, copy ALL the pictures to your computer and then format your memory card using your camera.
Note: all pictures on your memory card will be deleted when you format it.
I hope this helped you.
-damneddle
Oct 11, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
How do i make sure that the date is on my pictures when i take a picture from my Sony Cyber shot camera
because the image is digital, the camera will ALWAYS stamp the date into whats called the 'metadata'. you wont see it on the actual image but there are many ways to view it.. if you have a mac, just right click the image and "get info". if you want the date visually stamped on the actual image, go to your camera settings and turn that option on. im not sure what model you have, but it should be an option good luck
Mar 06, 2011 | Cameras
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Dec 22, 2009 | Kodak EasyShare CX7300 Digital Camera
The lcd screen shows white image when taking outdoor photo
i was taking picturres with my canon A470 digital camera and when i review the pictures that i take, the pics were very bright that you cant view well the pics. what is the problem with it? it just suddenly happened like this.
Oct 25, 2009 | Canon PowerShot A470 Digital Camera
Reads CARD FULL, can't view the pics, reads NO IMAGE
Sounds like the card has died. unfortunatly this can happen. and could be caused by a number of things including static.
you can maybe try a disk repair in windows.
hit your windows key and press r at the same time. in the command line type CMD and hit enter, it will open up a DOS window. type CHKDSK ?: /f where teh question mark is, is the drive letter that windows has assigned the card when you insert it. if it is an error that is repairible this might work.
Sep 23, 2009 | Olympus SP-560 UZ Digital Camera
Image problems - samsung L100
You can try a different memory card, but I don't think the problem is memory card, if pictures look scrambled, and colors and brightness are not uniform, that is either a problem with CCD sensor (optic sensor that takes the picture), or logic board.
In either case, this is not an easy repair.
Reset the camera to default settings from camera menu, and try a different memory card, but the camera will probably need to be sent in for repairs.
Jan 02, 2009 | Samsung L100 Digital Camera
The Sandisk memory card in my camera says memory card full but when I try to view the pictures it says no image. My computer cant read the pictures either. I know its full because the battery died while...
The card may have been ruined if the battery died in the middle of taking a picture. If the card looses power during data trasfer it damages it. You could try formating the card or you may just need to get a new one. Be sure this is the problem before you format it. Because you will loose all the pictures on it.
Dec 12, 2008 | Cameras
File Contains No Image!
Does the camera have internal memory? The folder name might not match the folder you or the camera are looking for. REmove mem card and see if the pics are still on the camera, if so, then try again without the card in. try and see the card in "mass media storage" mode on your PC. Reformat the card in the camera after you get the pics off to reset the folder name.
Dec 01, 2008 | Nikon Coolpix L11 Digital Camera
Camera shows small pics in viewer
the card was the problem. Changed the card and all is fine.
Apr 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Feb 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
60 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
