Hi Good day!! try to run your windows in Safemode, to run in safemode, press f8 continuously while booting your pc. Option will appear after pressing f8 choose safemode. your pc will start in safemode. after that do some scanning and then reboot your pc see if your windows will start normally. if not work please relpy to me and i will assist you more thanks!!!
Don't forget to vote Thanks!!!
Dear friend the problem is really very very common problem.
Generally system restarts suddenly due to OS (here Windows XP) problem, RAM proble, SMPS problem - but here definitely the restart is due to OS problem and you must re-install Windows XP. And for that you must need a CD/DVD drive or writer. Please buy/collect an external optical drive(CD/DVD/CDW/DVDW) - and re-install or repair the OS.
N.B.- 1. Many times we found in the process of installing Windows XP the partition containg Windows XP damaged logically - so you must re-install OS.
FOR ADVANCED USERS
If the partition is lost and you are facing this restart problem - you may recover the partition - and before you may use Knoppix linux CD to recover the valued documents. then you remove the HDD from Laptop and run data/partition recovery software in another hard disk attaching this faulty HDD there. You may recover the partition and autometically the restart problem will be solved.
I think I have given you all possibl;e suggetions - please try very carefully - and you may recover the documents also.
