the manual states to go to the Screen menu, but the option of "Adjust Projection TV is not there, any idea how to get it back?
Clarification Request
by salt56, posted on Jun 16, 2008
How bad is your convergence problem? If I remember correctly the adjustment is there just search a little harder...and if the problem is too bad you must change the chip on the module inside the set. Looking at the back after taking the back cover off it is the module that unplugs about 1 foot over the main chassis that is on the bottom. A rectanglular with two plugs and the black chip on the aluminum heat sink is part number stk 730-130 or stk 730-010 both will work...must be unsoldered and resoldered new one in.... Dennis call Tritronics at 1-800-638-3328 I believe is the correct number or go online for search...maybe Parts Express online
Post a New problem for RCA P52937 52 in. Rear Projection
Email this problem
Can you Help with these Projection Televisions problems?
blurred double picture
same problem as you
Won't power up
P52738wk wontturn on
