Question about HP DesignJet 100 Plus InkJet Printer
Colors Not Plotting Correctly
I have a HP110 Plus. The black is fine, but when plotting green or grey, the colors is streaky and appears as if one, or all, of the three primary colors isn't working properly. The cyan appears to be dominant. I use mainly black, could the color cartridges be drying up? I recently started using a remainufactured black ink, could that have a negative effect? Or is it something else altogether?
  • 300 Answers
You should try calibrating the colour and performing a print head alignment, if this doesn't work replace the colour print heads
Posted on Jun 10, 2008
Deh 6 wire colors
normally the speaker wires have a matching coloured wire with a black strip and are distinct from power (red/yellow) , ground (brown/black), aerial (blue) , remote power etc. Not always the same but sometimes grey/grey with black stripe, green, green with black stripe.
Aug 27, 2014 | Pioneer Car Audio & Video
Is there some way you are supposed to be setting up the calculator before you use it?
That would depend on what you want to do with it. If you want to graph a polar plot, for example, you'd set it for polar plotting. If you want to graph a parametric plot instead, you'd set it for parametric plotting.
Jan 16, 2014 | Texas Instruments TI-84 Plus Silver...
I have plotter HP designjet 500 24" but when plotting from autocad do not plot in gray color, even though layers as assigned in light colors on the plot style.
You need to set up your pen assignments in Autocad, have you done this? ie, Pen1 is 0,25 black, pen2 is 0,35 blue etc,etc. If this is not done you will have problems with colours and line thickness's.
Jun 25, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
I was plotting graphs of quadratic functions and all of a sudden i had error message: INVALID DIM. What do I do?
If you were graphing equations in the y= screen, chances are that you have Plot 1 or one of the other plots on. You can tell if this is the case if you have a black box over plot 1, plot 2 or plot 3 in the y= screen. To turn of the plot with the black box over it, arrow up and over if needed to highlight this black box. Press enter and you will turn the plots off and should be able to graph.
Another solution is is press the 2nd key, then the + key, then the 7 key, then the 1 key & the 2 key. This clears the RAM and resets the calculator to the original factory defaults.
Remember.....2nd....+....7.....1....2
Hope this helps/
Jun 19, 2011 | Texas Instruments TI-84 Plus Silver...
I have the TI-84 Plus calculator and when i try to graph anything, it says ERR: WINDOW RANGE. What do i do?
Press WINDOW (the second key on the row of function keys at the top of the keyboard) and check your settings. Alternatively, if you're plotting a function press ZOOM 6 to set the standard window range and if you're plotting data press ZOOM 9 to set the range to go with the data.
Oct 19, 2010 | Texas Instruments TI-84 Plus Calculator
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
I need to know the color coded wires for a car stereo, pioneer deh1500. whats speaker colors, power colors and constant power
The power color is red,the negative lead is black,the constant power is yellow.Now for the speakers ,the white lead is the + and the white with the black line on it is the - wire ,grey wire + and grey with black line wire - ,green wire + and green wire with black line wire -,purple wire + and purple with black line -.Hope that clear your mind.
Dec 09, 2009 | Pioneer DEH-1500 CD Player
Need wire colors power,ground,speakers/clarion arx6670zterryrose
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Oct 12, 2009 | Clarion ARX6670Z Cassette Player
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 100 Plus InkJet Printer Logo
366 people viewed this question
Ben Johnson
