Question about Sony PlayStation 2 Slimline Console
PS2 Slim disc reading problems
Hey, this os Robert.
My PS2 slim is having trouble reading discs. I've tried putting something on the lid, rubbing alcohol, and cleaning the discs themselves, but nothing seems to work. Please help, it would be much appriciated.
Thanks,
Robert
  • Anonymous Jun 11, 2008
    DISC ERROR
  • Anonymous Jun 13, 2008
    gets stuck loading games and sometimes just goes back to main screen after tring to load games. cleaning lense sometimes helps but mostly same result after cleaning
  • 107 Answers
Try cleaning the system.
Get a can of dust remover and thoroughly blow out the system.
MAKE SURE NOT TO SHAKE THE CAN OR TURN IT UPSIDE DOWN THIS WILL CAUSE FREEZING LIQUID TO BLOW OVER THE SYSTEM POSSIBLY CAUSING DAMAGE!!!
You will also need a laser lens cleaning kit, both of these items can be purchase @ Wal Mart, Kmart or Target for about $25.00
Posted on Jun 12, 2008
Slim ps2 says "unable to read disc"
You might need a new DVD drive too. Sounds like you need expert help, i had sent my PS3 to videogame911.com after i attempted to work on it my self and they repair everything, even saved my data. Got it back within the week and at a very reasonable price. Hope this helps you.
May 03, 2013 | Sony PlayStation 2 (PS2) Console
The disc on my slim ps2 rubs against something on slim ps2. It leaves a big ring around the disc
The disc is most likely rubbing on the laser lens. The lens is held on rails which is held up by rubber boots that may have came loose and/or popped up forcing the laser lens to close to the disc. Make sure disc tray is aligned properly as well.
Jul 19, 2010 | Sony PlayStation 2 Slimline Console
Playstation 2 slim will not read discs. disc inserted and door closed still nothing happens. no laser movement, nothing.
There are THREE reasons that a Slim PS2 will not read discs. I willstart from most common and end at the least common (almost rare)problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other videogame] consoles. They eventually fail, especially if you use your PS2as a DVD player. You can find Slim PS2 lasers at the followingwebsite. They are pretty simple to replace:
http://store.richspsxparts.com/v12laser.html
2. There are two "lid closed" sensors on the Slim Playstation 2. Theylet the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn'treally happen by itself... usually if someone drops the console, one orboth of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someoneinstalled a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting todetermine why your PS2's discs aren't spinning, and how to fix it.
http://store.richspsxparts.com/slpsnospdi1a.html
Nov 07, 2009 | Sony PlayStation 2 Slimline Console
Slim PS2 won't read CDs
try cleaning lens with canned air and wipe the rubber ring on the drive motor off with a microfiber towel moistened with rubbing alcohol
Jan 13, 2008 | Sony PlayStation 2 (PS2) Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Disk Error...Grinding sound when i put it in
I think you will also have trouble with reading Audio CDs. This is s sign that your Laser is dirty. The following procedure is for the older Big PS2. It will not work for the Slim PS2 model. Do not ever use Alcohol on the Slim models Laser Lens.
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Playstatiion 2 repair
Hi Jaybs,
The disc will not spin if the laser canot read the disc. you may have a dead laser or bad ribbon cable that runs from the Laser to the motherboard. I am posting a procedure to clean the lasers lens. I hope you do not have the Slim model, as this procedure is for the older Big size PS2. You do not use Alcohol on the lens of a Slim PS2 ,it tends to haze over the lens.
Won't read disc.
Hi Crashley41 and Von281,
Since you have the bid Phat mode; you will have better luck at fixing your PS2.
This is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you still have trouble reading discs. Click on " Repair Directory" at the bottom of this screen. Then on the next page click on "Video Game Consoles". Pick a Repair shop to get your PS2 repaired. Fixya has some good ones dedicated to Playstations.
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
  4. REmove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. REmove the little white disc from the Cd tray lid.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
