Question about Danby Portable Air Conditioner
Compressor is not kicking in
My 12000 BTU air condition was working fine till we got the thunderstorm,the power went out for a second, the fan came on but not the compressor. any suggestions?
  • candoose Jun 11, 2008
    The compressor of my 12000 window type Danby A/C quit working after the surge.Is it something simple I can fix myself. The unit is 12 years old. Is it worth to fix or buy new one.
  • 95 Answers
Probably power surge shorted out the main board. If so it will need to be replaced. Gotta call for service.
Posted on Jun 10, 2008
Fan runs , but when compressor kicks in unit trips wire and quits
problem in the compressor
have a technician check it out for a dead short or problem motor
May 08, 2016 | Kenmore 12000 BTU Air Conditioner
Why incessant beeping?
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
Put a filter on it please.
Jul 10, 2011 | Goldstar Heating & Cooling
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
I have installed an LMU246 with two heads. One 9000 BTU and the other is a 12000 BTU. The 12000 seems to work fine but the 9000 head dosent cool and when I tried it on heating, a c7 code comes...
with the Lmu24 you have a variable speed compressor i wouldn't suggest attacking this repair on you own, get a Nate certified Sr. service tech out there and have them do cause your taking about high end cutting edge compressor technology, how ever if you need them i can email you a pdf copy of both owners and service manual.
Oct 01, 2010 | LG LS-K1830CL Cool Mini Split Air...
Frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
GE Air conditioner cannot kick into airconditioning mode
it sounds like either the start components for the compressor have failed or the compressor itself has failed, since it is not kicking the breaker I would lean towards start components.if it is a PSC only comprssor, you may be able to add a start assist to get the compressor started. I assume that since it is 8000 btu it is 110VAC you can probably get a generic start kit at your local appliance parts house. they have a diagram and are fairly easy to install, just be aware that the capacitor storea charge on the OFF cycle, and can be dangerous
Jul 19, 2009 | Heating & Cooling
Hello :)
1. Switch off the AC first for a few hours
2. Remove the power connector
3. See that the Compressor is cool first
4. check the air tube and the blowers
5. Reconnect the same and connect the power cables
6. Swith on the AC then
If your problem solved plz rate me
Feb 24, 2008 | Heating & Cooling
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Danby Portable Air Conditioner Logo
190 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
