Question about Goodman CLQ36AR49 Air Conditioner
Goodman 3.5 heat pump
My air conditioner is blowing out hot air, I called a repairman to check it and he told me the compressor was locked in a unit that is 5 years old. He said it would cost me 1500.00 to have it replaced. How do I know that the problem is the compressor? also what is recommended.
  • 95 Answers
Does the breaker blow when you turn it on? If it does then the compressor is certainly shot. I would spend a couple of bucks and get a second opinion. As far as price $1500. is a pretty good deal for a new condensor.
Posted on Jun 10, 2008
Goodman model aruf486016AA is not blowing hot air
Need more info. Does blower come on when calling for heat?
Nov 11, 2013 | Goodman Manufacturing Goodman ARUF486016...
I have 2.5 Goodman heat pump, 3 yrs old, the sucsion pressure is 90 PSI, the discharge pressure is 180 psi. I am told the I have a bad compressor valve. Please, tell me how can I fix a bad compressor...
The piston is too large. Have a reputable heating and air technician install the proper size piston and this will correct the problem. Cost should be 150.00.
Sep 02, 2011 | Goodman CKL24AR24 Air Conditioner
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Central air Goodman ck30-1a blowing fuses?
I don't know what you use to heat your house, (heat pump, gas, oil) but if it is not a heat pump, i.e.. you don't use the outdoor unit to produce both heat and cooling, then the first place to look is at the compressor in the condensing unit (outdoor unit). If you have a bad capacitor, it will cause the compressor to pull locked rotor amperage (LRA) for an extended period of time and will cause the fuse to trip (usually within 2 or 3 seconds) The other possibility would be that something got into the wiring and have created a short. I have seen more insect and rodent damage to wires then you can imagine, so this is also a high possibility. Hope this helps
Apr 03, 2010 | Heating & Cooling
I have a goodman ac/heat pump....worked fine last season...now only blows cold air, even in heat setting....help! thanx
Heat Pumps are not famous for being fast heaters. Give it some time to act. Is yours extracting heat from the air or from a water source. If from the outside air, consideration must be given to the temp of the outside air. It takes longer to warm as the temp outside drops.
Yours could be a different problem of course, but let it have a chance to work before you call the repairman.
Dec 12, 2009 | Goodman CLQ36AR49 Air Conditioner
I have a CPLE24-1 split system. heat not working
I dont know where you are located but anything bellow 45 degrees a heat pump does not put out much heat. As it gets colder the effeciency goes down. So if you have 24,000 at 60 degrees outside at 45 it is 15,000. Now first thing have the charge checked. If a unit is one pound low it can loose 20 %. Next see if your auxilary heat is working . You have at leat 8 KW backup heat.This comes on the second stage about 2 degrees or 2 to 4 minutes behing the Hat Pump. Ask service tech for free estimate or call and get season check. They will go thru your unit and check everything and let you know what wrong and also clean the system. Cost about 49.00 to 69.00. I own a business and we sell a maintanance contract for 105.00 and check and clean the system twice a year.Keep in touch Rus
Nov 25, 2009 | Goodman CPLE24-1 Air Conditioner
Goodman Air handler blowing fuse if switch outside unit not runni
Sounds like your compressor in your heat pump is siezed . You can try a "Hard Start" Capacitor...which basically gives your compressor a kickstart and works 95% of the time when compressors get older....It's hooked up in parallel with the existing Capacitor...if you're not familiar with Electrical etc I would call an expert and mention what I said . If this doesn't work you will likely need a new Compressor/Unit . You could also have a short to ground in the heat pump side....likely the compressor is the problem however the original Capacitor could also be the problem
Oct 27, 2009 | Heating & Cooling
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Goodman model cpe30-1ab heat pump fan not turning. Air is coming in. I have a call into the repairman, just want to get a headsup. At one point I saw smoke coming out of the unit.
usually if the fan failed the heater will overheat maybe the smoke you saw was coming from the heater. Let the repairman to repair the fan.
Jun 08, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
110 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
