Question about GE Refrigerators
NEW REFRIGERATOR TRANSPORTED ON SIDE YESTERDAY IT WON'T START COOLING 24 HOURS LATER HOW LONG SHOULD WE EXPECT IT TO TAKE AND SHOULD IT BE PLUGGED IN OR OFF???
    Problem Solver:
  • 8 Answers
It is very likely that oil may have traveled into the refrigerant tubing from the compressor. It may take a couple of days to let it drain back, or it may not drain back at all because of the way the bends are made in the tubing.
You may have to have this unit serviced by a qualified technician. The technician may be able to pull a vacuum on the unit and save it from the junk pile.
Posted on Jun 10, 2008
GALANZ 2.7 Mini Refrigerator Model # GL27BK Brand new, won't keep anything cold , even on the highest cold setting.
Well, it's under warranty. You take it back and ask for a replacement. You have given it sufficient time to cool.
Oct 17, 2015 | Refrigerators
Moving my fridge on it's side or at an angle
You can lay it down but if you do, when you stand it up, wait 24 hours before you plug it in to turn it on. The reason is because the oil in the cooling system has to settle after being layed down.
Jun 01, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
May I safely transport a refrigerator laying on its side?
yes,but let it sit still after you stand it up for 24 hours without plugging it in to allow the freon to settle
May 14, 2015 | Refrigerators
We had a new Samsung RS267TDWP side-by-side frig delivered earlier today. The refrigerator side is cooling off nicely, the freezer side is not. Should we expect the freezer sideto begin cooling when the...
It takes approx. 24 hours for a freezer to reach optimal temperature and to stabilize, only because in a 24 hour period the machine will shut off about three times for it's defrost cycle, but like you listed, freezing temperature will be reached in about 6 hours.
Aug 29, 2012 | Refrigerators
Moved from home where it was working properly to another home. When plugged in at new home it is not cooling inside the freezer side or refrigerator side. What could of caused this type of problem? What...
IT COULD BE A SIMPLE SOLUTION
If your refrigerator was transported on its' side you may have to let the freon settle before plugging it in to receptical. (about 24 hours) Try this first.
Mar 09, 2011 | Refrigerators
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
Frig not cooling-water line frozen
Check to see if the fan in the freezer is working. It moves cold air from the freezer side to the refrigerator side. If it is not working or if there is an obstruction in the duct work the issue could be there. Fans and motors are cheap and easy to replace.
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
We move my refrigerator and it was laid down for about 2 hours we plug it up when we got home now it won't get cold, how long will it take to start getting cold it been about 2 days now
It shuld never be layed down for transport or storage. 2 Hours is not a long time but you should have left it upright overnight before plugging in. turn it off for 24 hours. When you restart it it should be cooling in a few hours and at normal temp in 24-48. If not you may have damaged the compressor. (Assuming you hear it running)
Eric
Dec 23, 2009 | Kenmore Refrigerators
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Pluged in a new one and it does not seem to be cooling off
did you tilt it prior to plugging it in you are supposed to wait 12 to 24 hours to plug them in if theyve been tilted at any time during transport.
Dec 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
