Backlight Sometimes when I turn on my laptop or try to wake it up the backlight doesn't come on. I usually can just shut the screen then open it again and it comes on but sometimes I have to shut down my computer and restart it.
  • gaby_25uk247 Aug 20, 2008
    acer aspire 5630 backlight problem
  • dmar29
    dmar29 Mar 29, 2009
    No back light on the screen, if i place the screen into the sunlight i can see the windows working on the screen.
    Some times when i turn on the p.c the screen will be o.k for 15min then turns to black,but the systen works fine.
Your problem is the backlight, changeit and solved the problem....
http://articulo.mercadolibre.com.mx/MLM-28562362-lampara-backlight-para-lcd-de-laptop-acer-compaqdell-_JM
i buy this and i kick this problem....
Posted on May 10, 2009
    Problem Solver:
  • 18 Answers
If you are running windows, you might have to re-install your operating system, if that doesn't work, you might be having a bad system board and or memory.
Posted on Jun 10, 2008
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
Backlight wont turn on I have a MC218
If you have a very dim display, or no backlight it could be due to a few things. A loose LCD cable could cause the problem, a very basic way to test this would be to apply pressure to various parts of the laptop case and screen bezel, also move the screen and see if a backlight ever powers on. If you are comfortable opening your laptop to check connections then do so. A faulty cable is also a possibility. Sometimes it is a software issue, try turning your display brightness up to max, does the backlight illuminate when in BIOS? If so it is a software problem. Finally it could be a failed LCD inverter, this is a bit of hardware usually separate from the LCD although is sometimes built onto it. These are generally easy and reasonably cheap to replace.<br /> <span style="font-size:12.0pt;font-family:&quot;Times New Roman&quot;,&quot;serif&quot;; mso-fareast-font-family:&quot;Times New Roman&quot;;color:black;mso-fareast-language: EN-GB">Hope this helps,</span><br /> <span style="font-size:12.0pt;font-family:&quot;Times New Roman&quot;,&quot;serif&quot;; mso-fareast-font-family:&quot;Times New Roman&quot;;color:black;mso-fareast-language: EN-GB"><a href="http://www.putercare.com/">www.PuterCare.com</a></span><br />
Aug 27, 2010 | Computers & Internet
Dell XPS M1330 Backlight Problems
Really does sound like a backlight problem. They usually don't cost much and are easy to replace if you are good with a screwdriver.
Apr 25, 2010 | Dell XPS M1330 Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
HP pavilion notebook screen turns black after flickering
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | HP Pavilion DV5Z PC Notebook
Dell Inspiron B130 won't wake up after closing lid
Right Click on desktop--> Properties--> ScreenSaver-->Power--> Advanced
And from there U can set the things According to u
Hope It Solved Your Problem
Good Day
Apr 13, 2009 | Computers & Internet
Monitor does not wake up.
Check the inverter and backlight bulbs.
Mar 27, 2009 | NEC MultiSync LCD1550VM 15" LCD Monitor
T43P LCD keeps going dark
I think you are having problem with backlight. The concept of laptop is that if there is problem with backlight then it will try to shut it down(shut the light down).If you restart your laptop ,that mean you turn the light on again...after that if its blink or something wrong then again your system will try to shut it down to prevent other part get spoil.
What you have to do is..
1.problem from backlight replace backlight
2.problem from inverter replace inverter
3.problem from motherchip...repair motherboard.
Byebye,takecare
Apr 22, 2008 | IBM ThinkPad T43 Notebook
Open Questions:
Online backup and storage 'DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
529 people viewed this question
David Payne
David Payne
