Question about Honeywell Heating & Cooling
My Honeywell T87F Thermostat doesn't shut the A/C off when the temp in the room gets down to the Thermostat setting. I have it set on COOL and AUTO. I have to shut the A/C off; then later turn it back on as it gets warmer again.
  • 95 Answers
Remove the thermostat and disconnect the r and y connection. If the A/C continues to run ya got a short in the wiring somewhere. If it shuts down then your tstat is hooped.
Posted on Jun 10, 2008
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Honeywell th4000 thermostat - fan won't come on. The system set to cool and the temp is set lower than room temp.
That problem is seldom the thermostat.check all fuses and breakers....if they're ok,its prolly an internal problem to the furnace.
Aug 24, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
331 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
