Question about Frigidaire GLER642A Electric Dryer
Dryer plug issues
We've recently moved into a new home and when we tried to connect the dryer the plug would not fit the socket in the wall. So we bought a dryer 4 wire power cord, changed out the plug and now it won't work. Please help!!
Excellent
Posted on Feb 13, 2009
    Sergeant:
  • 291 Answers
For 3 wire Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
for 4 wire Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Posted on Nov 23, 2008
My maytag electric dryer has worked perfectly fine for 10 years. today i unplugged the dryer and did some work on the wall. when i plugged the dryer back in it tripped the breaker. could it be the dryer or...
You already unpluged before the wall work, so the problem is isolated from the dryer from its plug. Take off the wall socket to inspect since it may have damaged. If you have the voltmeter, measure each pair of the terminal. they should have a voltage at least 110V since it is three-phase voltage. If there is no voltage then just replace the socket. Make sure to turn main power off when you do the replacement.
Apr 27, 2010 | Whirlpool LER5636P Electric Dryer
I need to know what type of power cord to use with a Maytag sde2606ayw dryer. I have a dryer but no power cord. I have no idea about what to get and how to determine what to get. thanks, Patrick
Hello Patrick. dryers do not come with a cord because there are two very different and very common dryer sockets installed in homes in this country. look at your dryer socket, where you will be plugging in your new dryer. It is either a 3 hole or a 4 hole socket. IF it is a 3 hole socket then u will need a 3 hole plug. If it is a 4 hole socket you will need a 4 hole plug. The plugs are available at Sears, Home Depot, Lowes and they all come with instructions.
please rate my answer as very helpful. thanks Joe
Apr 03, 2010 | Maytag HYE3658AY Electric Dryer
Having trouble connecting the dryer to the electric socket in the wall. They are differenent What do I do?
Purchase the correct wall receptical needed to fit the plug on the dryer or purchase a new cord that will work with the wall outlet to fit the dyer. Either way will work that is easiest for you
Mar 29, 2010 | Dryers
Spark came out of the wall receptacle after moving
loose connection on the 220 plug in the wall ....go to electrical panel in your home and turn off both breakers to the dryer...this could cause a fire...call an electrician for repair
Jan 03, 2010 | Kenmore 93862 Top Load Stacked Washer /...
Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
Nov 16, 2008 | GE Dryers
Electric cord
What you should get is a new 4 wire cord. It is way less complicated than trying to change out the wall receptacle.
On a 4 wire dryer cord you have White(common) in the middle. Red and Black are hot and go on either side of white. If you really want to make it look good you can put red to red on the terminal and black to black but you don't have to. Some dryers may not have those color hot wires. Green hooks to the chassis with a green screw or any screw connected directly to the frame.
Jul 21, 2008 | Kenmore 62802 Electric Dryer
Problem with my dryer
unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
Mar 24, 2007 | Whirlpool LER2614JQ Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
98 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
