Question about GE WSXH208A Front Load Washer
Bleach is being held in basket, after many uses.
  • Greg P
    Greg P Sep 30, 2008
    I have the same problem. Put the bleach in for a whites load...turn the selector to "Whitest Whites" and after the load is done I still have a full cup of bleach.
  • rhmeshel May 11, 2010
    So how do you unclog it?
  • 1,224 Answers
Clog in bleach drain possibly hair or material in bleach release basket
Posted on Jun 10, 2008
I just recently moved and the Washer was left here. model 2110 I am using the same detergent. Don't use bleach. My dark clothes are looking like I used a faint tie dye. What could be wrong
Ok, this is a top loader correct ?? It may have been used to wash dirty oily rags ( too much bleach ). It could have also been over loaded and something got in between the tub and basket wall/ ( a marker, a pen or something small like that ) if that is the case it could have made it down to the pump area.
to start trying running a few empty loads ( HOT ) and see if you flush it out.
does this model have a special place for the bleach ?? Poor hot water down there and flush that out too.
Dec 14, 2017 | Washing Machines
I get a very strong smell from my maytag atlantis washer. it smells like the sewer. how do i remove that smell?
Confirm that the sewer trap is working. The sewer trap for a washer is the pipe connection where the washer drain hose connects.
It would not be likely that the trap is a problem. Sewer gas and mold can smell similar. Smell around the hose connection. Some older homes just simply had a drain to the outside
26162560-vtficdakbbyhbpkipaftpy0h-4-0.png Next this machine is a top loader and if it is being used several times a week the problem is likely around the tub on top. Mold will form in the tub under the basket if it is not run weekly. Normal wash cycle in a top loader should keep under the basket clear. If a week or so occurs between use then the problem can be under the basket at the bottom of the tub. Use bleach, vinegar, or baking soda in moderation to clear.
It is more likely that the problem is around the top of the top. this requires opening the top and swinging it back to get access. Make sure power is removed before attempting.
Cleaning a little bleach, soap and water.
26162560-vtficdakbbyhbpkipaftpy0h-4-9.jpg this helps?
Apr 13, 2016 | Maytag Washing Machines
To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
The machine could handle easily one full laundry basket -- see below.
  • Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
There is a musty oder coming from inside washing machine.
Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
Good Luck
Aug 08, 2009 | General Electric WBVH6240HWW Front Load...
I can't get the front panel off my HE3 #44836 to clean the filter. The rubber backing crumbled on my bath mats in the washer. I vacuumed out the tub, but where did the rest of the rubber crumbles go? ...
Read the owners manual. Many washers have 'self cleaning' filters that will get clogged with big stuff. The 'moldy odor' is caused by MOLD. Run a 'extra large' empty load of HOT water with normal detergent + 1 PINT of ordinary bleach. Add another shot (pint) of bleach to the rinse cycle. Sometimes a small article (sock?) will escape the clothes basket and get trapped in the tub--it can't get drained out and can't get back into the clothes basket. The bleach will kill the mold, but if it returns you will have to take the top off and fish the lost article out using a bent clothes hanger as a hook.
Jun 19, 2009 | Kenmore Elite 45986 Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
Place a load of sorted clothes into the washer. See “Laundry
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Maytag Washer, Model # MAH4000AWW (Neptune - front loader) appr. 4 yrs old
Hi john, There is a blue cover that i am suspecting you are missing from the softener/bleach dispenser. It fits over the two tubes in the dispenser and it siphons the water out. It is part number 22002266. Also the machine has a water filled balance ring. It is normal to hear sounds of water when the tub is turned. If you can see water in the spinner its a different story.
Nov 24, 2007 | Washing Machines
GE WSXH208A Front Load Washer Logo
51 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
