Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Problem with a pendrive
can you just help me with my problem please?
when I'm trying to delete or write any data in to the Flashdrive there is a message popping up which is saying: Disk protected from recording data...
is any solution to resolve that problem or i have to send it out under warranty?
thank you
    President:
  • 1,257 Answers
First try to see if there is any switch type lock in your media device or adapter and see if its not locking that media..it looks like slide switch .for one end it will lock the media and when you slide it to other side you have full access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 16, 2008
I had a pendrive of 8 GB my friend tried to make a bootable pendrive so he changed some settings by command prompt. My pendrive storage capacity dropped from 8 GB to 3.44 GB I need a good solution please...
It seems that after your friend made it a bootable pendrive, he/she did not format it.The space has been used up by the installation files in the flashdrive,and these files may be hidden.This is likely to be the case with some command-line utilities for making bootable flashdrives.
To recover your space, simply format your USB pendrive.To do so on Windows XP,insert the flashdrive into your PC, go to My Computer, right-click the USB pendrive,and in the window that appears, click the tools tab and select the Format option.
That should solve your problem.
Jan 25, 2011 | Computers & Internet
When i insert my pendrive its coming that device
DID you tried different USB ports?
IF YOU DNT NEED the inside data you can always format it.
..using any usb format tool (DriveKey), or u can even go to administartor tools, device managment, disk managment, locate your flashdrive and format, it will be back to normal state after that.
Jan 01, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pendrive identified but not accessible
Hey I have solved the problem posted by me yesterday regarding pendrive not being accessed. It is a Transcend pendrive of 2GB capacity. I went to website www.transcendusa.com. Then I went to Tech support and selected my location(eg. India) through their user friendly menu. Then it asked for the product. I mentioned USB flash drive. Imediately it displayed an ONLINE recovery. I selected the pendrive from USB flashdrive. i.e mine is V series, V30. Then through the download link provide for different operating system viz. in my case windows XP I downloaded the onlinerecovery.exe file, plugged in my pendrive. It gives option of repair & retaing data or Repair & erase data. I went for the first one and my pendrive was repaired in 5 minutes and my data was restored intact. I got back all my files. Hope this will be very useful to Transcend pendrive users. Most of the problems are repaired by them the firm claims. Try it out and happy pendriving.
S.V.Raghavan
Bangalore
Sep 23, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
32Gb kingston pendrive not working. Any data copied get corrupted
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
Jun 27, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't delete some data already installed in Kingston pendrive?
What type of files are they (be more generic if files are personal and/or name the extension names of each files that cannot be deleted)
Solution:
- Try changing the name of the files and then deleting them
- Is your USB Password Protected ~ this may stop you from deleting those files (try deleting the Security on your USB)
- System Deletion Performance may be slow and.or unknown Deletion Command
Hope I helped
- donman92
Jun 01, 2009 | Computers & Internet
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive not opening on xp
Appreciate the direct "Ask Me".
Initially, pls try the pendrive in another computer to verify that it is a pendrive's issue and not the PC's USB port.
A couple of things you can try:
  • use a file recovery utility/program (such as GetDataBack) if there are important files in the pendrive;
  • go to the pendrive's manufacturer's website and download (if available) recovery software;
  • use a utility program to scan/clean/fix, something similar to ScanDisk or Norton Disk Doctor.
If the above will not work:
  • format the pendrive and try to an un-format/recovery software;
  • format the pendrive using HP USB FlashDrive Utility; adn try again a file recovery software.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 19, 2008 | Computers & Internet
Pen drive not showing in My Computer
hello sr my pendrive wn i connect to my pc and it is not showing and option in my pc so is it any damage at pendrive and how can my pendrive work
May 19, 2008 | Electronics - Others
Pendrive
hi, glad to solve the problem you have
these are the following things you can do
>> close all the process running from your pen drive
>> even then if the msg is coming then use another pen drive and see if the same msg is coming
>> if same msg comes problem lies in your computer which can be caused due to some virus or a trojan.
solution:
try using a enterprise version of any anti virus,.
thank you
Mar 05, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
