Question about Kodak EasyShare C875 Digital Camera
Flash not working and camara seems to keep turning off
Hi the flash doesnt work anymore are they any parts that may need replaced that i can fix myself?
  • wherbie Jun 20, 2008
    same prob...no flash...seems to be common on these...ant ideas?
  • ashley_ehlke Jun 21, 2008
    Flash stop working on my camera, what can I do to fix it?
Jfiodjfmkldmsfldsdms
Posted on Jun 13, 2008
Flash/dark pictures
If this camera is new, take it back.
Apr 28, 2010 | Kodak EasyShare C613 Digital Camera
Phone repair
HI,
I strongly suggest you to get it serviced from the nearest service center located in your area.And this is the only solution to fix this up.
Goodluck..
Jun 12, 2008 | Sony Ericsson K790i Cellular Phone
MY FLASH DOESNT WORK ANYMORE!!! WHAT TO DO?
The flash bulb is seems to be damaged you may have replace the bulb in any local service center.
Feb 21, 2010 | Sony Cameras
My controller wont register with the ps3 anymore and i have the cable to charge it and it still doesnt work the lights just keep flashing but it doesnt register
Try another controller and see if that will register, if that doesn't try another usb cable for the controller and if the controller still doesn't register then that means the controller board is bad and would need to be replaced.
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
Flash doesnt work, flash icon keeps flashing, E:91:01 flashing
Hi
Try to reset your camera, heres one way of doing it
1. Turn OFF cam & Remove the battery or the power supply
2. Turn the switch to CAMERA for about 30 sec then & Turn the switch to OFF
3. Install the battery or power supply. & Turn the switch to MEMORY
4. Open the LCD cover and press the RESET button ( small inner button )
5. You will be prompt to adjust date/time.
6. Take some pictures and test out your flash
or open up the setup menu, and look for intilize or reset to factory defaults.
That should solve it, if it doesn't then its a hardware issue possibly the flash is bad some parts may need to be replaced to fix it. Take it to a local repairer or your dealer if your in warranty.
www.advancecamera.com will offer a free repair estimate if your outside of warranty.
Sep 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Flash
I gave the lense part of the camara a moderate slap, and the camara has worked fine since. looks like a lot of people have the same problem. Most of the people call it black screen problem. the shutter gets stuck. Tap it a few times on the side of the lense part of the camara moving it from bright to dark objects back and forth.
good luck.
Aug 18, 2008 | Nikon Coolpix S4 Digital Camera
No power.
there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
Jan 29, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Jan 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Olympus camara fe-230
go to manual mode and keep settings in which flash will come for sure.
Dec 28, 2007 | Olympus FE-230 Digital Camera
Camara locks up
Seems it could be a firmware problem You will have to go to the Vivitar Technical Support Team, on the Vivitar web site.
Jul 15, 2007 | Vivitar ViviCam 5340s Digital Camera
Kodak EasyShare C875 Digital Camera Logo
114 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
