Question about SanDisk Sansa E280 MP3 Player
Sansa E280 8GB Died
I was listening to the player and a song ended and I did not hear the next song start so I pulled it from my pocket to find it was off. First i thought maybe the lock slipped off and it turned off when i leaned against something, however this was not the case. It was off and will not turn back on. I put it back on the charger and it would not respond that way either. I plugged it in to the computer and it is not responding that way either.
Is there something I need to do to get it back running. I love this thing and have had is since it came out. I would not have an Apple Product so please tell me there is way to get it back running, as I would not buy another Sansa unless I have faith in the product and cant trust it right now.
  • 2,071 Answers
Test test
Posted on Jun 20, 2008
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Problem recognizing songs in sansa e260 mp3 player.
From what I'm hearing you don't have a good driver. If you still have the disk use that. If not google it or something. I have a Sansa e260 as well so I would suggest loading the songs on in windows media player rather that windows explorer. If you open Media Player and then go to sync and it does not recognize your device, then you have a bad driver. If not, then start syncing your songs that way.
Hope everything works,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
How do i fast forward through songs?
Press and hold the next song button.
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
I try to listen to one particular song, but Sansaclip 2gb freezes
Epsilon - delete that one song and see if the other songs play fine
unschool:
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
My Sansa e280 randomly restarts.
Try to reset it and reload the firmware.
Apr 01, 2008 | SanDisk Sansa E280 MP3 Player
No lit up screen or music
Even I had same problem. When showed it to technical person, he told me that battery has fused off due to water.
Oct 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Why is my battery draining so fast?
you must hear only two songs per day.
Aug 11, 2007 | SanDisk Sansa e130 MP3 Player
Duplicating songs
Does this happen every time you plug it into the computer? If so you might have your player set to automaticly sinc. this meens that every time you plug it in all the music on your computer will go automaticly on your player. In the settings you can turn it off. Hope this helps!
Jun 30, 2007 | SanDisk Sansa e250 MP3 Player
Sansa frozen
try taking off the back plate and take out the battery then put it back in and turn it on
Feb 08, 2007 | SanDisk Sansa e250 MP3 Player
Phantom Songs on my Sansa e250
Use Windows Media Player to delete, or double-check the format of those songs
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
