Question about Epson Aculaser C1100 Printer
SERVICE REQ. C0082
SIR, PLS HELP ME HOW TO FIX THIS PROBLEM MY EPSON ACULASER PRINTER C1100 AS IT APPEARS ON PRINTER KEY PAD MONITOR "SERVICE REQ. C0082"
  • 2 more comments
  • shelleyf Jul 11, 2008
    Hi I am receiving the same error message 'service req C0082' when i print via my apple mac, however when it is connected to my PC it works fine! how can i resolve this? Thank you!
  • jvanes Oct 07, 2008
    Epson AcuLaser C2600N - now shows SERVICE REQ. C0082 on the display and stopped working.
  • Anonymous Oct 15, 2008
    same... error shows ... and not working at all :(
  • Anonymous Mar 24, 2009
    My prinetr is Epson N7000.. Sometimes a red key is on and the msg "ser. request C0082" appears and I can't print.. Othertimes the msg become "Serv. request C0084." ..
    Pliz help me.
    Problem Solver:
  • 7 Answers
C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
Posted on Jun 18, 2008
  • Richard C Nolan Jul 02, 2008
    There is no way you can fix this without the help of the service technician. Money, money , money my friend, but there it is. Bite the bullet or get rid of the printer. Ouch!!!
We just turned the printer off for 20mins and the fault went away. That was nearly two weeks ago and it has not come up again.
Posted on Sep 18, 2009
On my AL-C2600 this turned out to be an issue with carbon on the power rails/ground rails that serve the fuser.
If you lift out your fuser you may well find that there are 4 black dots on the metal bed into which the fuser rests. You will find 4 corresponding dots on the fuser itself.
This is carbon, usually caused when electricity is not making a perfect contact and arcs across, you get carbon deposits as the metal is blasted away.
I cleaned these deposits off with some fine sandpaper and <crosses fingers> it's been fine for some time now.
I may put some copper grease in these locations to improve conductivity.
Posted on Mar 19, 2010
    New Friend:
  • 0 Answers
Message is Service E527 required
Posted on Apr 08, 2014
  • Geoffrey Race
    Geoffrey Race Apr 08, 2014
In our case apparently due to a bad ethernet cable. If the error appears after calibrating, and then you remove the cable and it doesn't, try replacing the cable.
Posted on Jul 20, 2012
EPSON ACULASER C1100 When running a given Message Service Req Error E537 Please help me
E537 is the Fuser error check the latch lever of the fuser assy is set incorrectly
Oct 09, 2010 | Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
Problem for Epson Aculaser C1100 Printer Error E542
Hi
Not much I can say for you I can only tell you what the error is but how to fix it I not know I try to look it up for you but every thing about this printer is in french,
Service Req E542: failure to clean the transfer unit
This all I can find Sorry.
All the best hope you find away to fix it
Pineworks
Feb 06, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
C1100 service req e527
Hi-
Try reseating the Photoconductor unit, or for step-by-step instruction to resolve this call 562-276-1300.
Hope this helps
Oct 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 Printer suddenly stopped printing
To my knowledge Error Code E511 refers to photoconductor and/or its associated components. It is possible that:
  • the photoconductor requires a bit of cleaning and to be reseated snugly;
  • the black rubber conveyor (transfer) belt inside the photoconductor moved away from its path;
  • the silver square reflector on the transfer belt needs cleaning;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
Epson C1100 aculaser
E527 Dev home position sensor error:
Possible causes:
MOTOR ASSY MAG
SENSOR ROTARY HOME POSITION
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Apr 11, 2008 | Epson Aculaser C1100 Printer
Service req E527 error
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
6,103 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
