Question about Garmin StreetPilot i5 GPS Receiver
Garmin i5 street pilot
My Garmin i5 street pilot stopped talking. I can still get directions, but the voice dosen't work anymore. Could this be a fuse problem.
  • thelockguy Feb 05, 2009
    Ever since the update my i5 dosn't talk anymore
  • 3 Answers
If you still hear clicks, then just reset it, you will loose all your waypoints so save them first
Posted on Jan 20, 2010
I had an i5 that lost voice. I fixed it by just replacing the speaker. Take it apart and measure the resistance on the speaker. If it is open or not 8 ohms, then you can use this speaker.
http://mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMuNFJjvCI6tQmnbmXzUsCMVOlE6Umf83Zs%3d
Good Luck
Posted on Feb 13, 2009
Garmin 750 stop saying street names
If you go to your languages, in the menu
Check Languages are
(( noted with a person's name ))
these are TTS text to speach voices,
Check they are set correct,
you should be good.
Hope this helps
Regards
Richard.
Apr 11, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Why stopped voicing street names?
As far as I am aware, Streetpilot C330 doesn't call street names. Check this specifications sheet on garmin's website:
https://buy.garmin.com/shop/shop.do?pID=6385#specsTab
Jan 13, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin wont read street names anymore
To activate the voice prompts, go to 1. Tools, 2. Settings, 3. Language, 4. Voice Language Option, 5 Select a Voice Option that includes a persons Name, eg Jack or TTS, Select OK and that should resolve your problem.
Dec 08, 2008 | Garmin nuvi 200W GPS Receiver
No voice audible
Garmin Street pilot i5 lost voice. Any suggesstions
Jul 29, 2008 | Garmin StreetPilot c340 GPS Receiver
Gps - street pilot i5 garmin
try this first-if the unit has batteries installed, remove them so unit runs on power cord only
Jun 01, 2008 | Garmin StreetPilot i5 GPS Receiver
Garmin nuvi 300t
He would not have nothing to say if you did not set a "where to"
Few words , you mean "turn right in 500 ft" . Its normal your unit type has only Voice prompts and not TTS (SPEAK STREETS NAMES) .
For your MP3 palyer it should work. Did you play with something in the setup.
Make sure you have the latest update 5.20.
Please use the GARMIN WEB UPDATER for best result.
https://buy.garmin.com/shop/store/downloadsDetails.jsp?id=1171&product=010-00455-01&cID=134&pID=339
Dec 27, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Street Pilot i5 Stopped working all of a sudden
Resetting Your StreetPilot
If your StreetPilot freezes (stops responding to button presses), try turning it off and then on again. If this does not help, remove the batteries and then reinsert them. Disconnect from external power, if necessary.
Clearing all User Data
If resetting does not fix your problem, you may need to clear all user data from your StreetPilot.
• IMPORTANT: zf you clear all user data, you will delete all saved locations from My Favorites I and all settings in your StreetPilot. Be sure you want to clear all user data before proceeding.
To clear all user data, press and hold down all buttons in the following order: ciJ, Wheel, Power.
Continue holding down all buttons until you see a prompt, “Do you really want to erase all user data?”
Select
Yes.
Nov 16, 2007 | Garmin StreetPilot i5 GPS Receiver
Street pilot i3 has stoped talking
1 had the same issue. Voice sis not appear at all in the settings, just text language was there. Did not want to reset and loose saved data. I plugged in to my PC, installed less maps to leave some memory free, then went throught the install process and selected a different language than US english. After install, it was back and it also talks French. Hope this helps.
Oct 22, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot i5 GPS Receiver Logo
170 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
