Question about Dell Inspiron 9400 Notebook
Something happened to my monitor screen .
The best way i can describe my problem is that my screen has went from normal to looking like a photo negative. white is now black and the opposite. peoples in photos are kind of highlighted (like a photo negative). if someone knows whats wrong, what should i do?
  • PabloAugusto Aug 29, 2008
    Auf ein mal, videos, Fotos, Flimmern, und das bild sehe so aus wie ein marmorierung..unruhige gesammtes bild auf desktop und anwendungen, sehr kleineres pixel fehler auf den simbolleiste..und der gleiche..
    Genius:
  • 2,028 Answers
Sound like your screen is going out, it could also be the inverter. Could also be the video card, but not likely. Before you go to changing out any hardware, go into the device manager and un-install the monitor drivers. The hardware wizard should pickup the monitor automatically and reinstall the drivers. Then look for any driver updates at the Dell support site. If that does nothing then it's either the screen or inverter.
Posted on Jun 11, 2008
What is this Sony LCD BX300 screen problem?
Man thats horrible
did this start happening when it was first hung on the wall?
Aug 16, 2014 | Sony KLV-32BX300 SERIES BRAVIA LCD...
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
Jul 04, 2010 | LG Flatron W2242P-SF 22" Monitor
Screen just goes all white then red,green,and blue color flashing
Is it that the screen just went blank or white without any display? need more clarification, but If it is, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
LCD monitor not working right
This is 2004 model, it may not be worth putting money and time into repairing a 15" monitor. But you can at least look inside for any damaged, burnt components, lose connections, etc. otherwise to do a component level repair at the shop will not be worth it.
See eample of what usually goes wrong with LCD monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 05, 2010 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Flat Screen monitor
There are hotkeys for the graphic display ctrl alt arrow key right turns normal, 90 180 270
Sep 22, 2008 | Dell Computers & Internet
My e153fpb monitor went dark
Try resetting the monitor to default settings by getting your manual out. It will guide you through the process. If that does'nt work then check for any updated drivers.
Apr 24, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor constantly displays "NORMAL" across the middle of my screen. I am unable to use any of the buttons on the monitor other than the power button. I've checked all the connections which are fine....
I would actually suggest to consider the drivers of your graphics adapter.
Try upgrading the drivers of your video card. If you already have the most recent ones, I would UNINSTALL the display adapter in Windows Device Manager...and reboot the system once more.
If necessary, I would roll back the driver to a previous version.
I suspect that perhaps there may be an issue with the refresh rate or something along those lines coming from your card to your monitor. Perhaps some kind of ratio issue?
One thing I would do is definitely check the manual to your monitor and find out what "Normal" really means. THIS is what I found:
"Lightview hot key
This feature lets you easily select the best desired
image condition optimized to the environment
(ambient illumination, image types etc).
• DAY : Bright ambient illumination
• NIGHT : Dark ambient illumination
• TEXT : For text images (Word processing etc.)
• MOVIE : For animation images in videos or movies
• PHOTO : For pictures or drawings
• NORMAL : This is under normal operating conditions"
So looking at that, I am led to believe that your monitor is switching viewing modes somehow. I would inspect the button that would potentially change these modes and make sure that it's not jammed somehow. It could very well be the problem causing your other buttons to be inoperable. (If it's somehow being held down by a foreign object for instance.)
Click HERE for the manual. (Don't enter your email addy. Just click the download button.)
That's about all I can really see as a problem without seeing it personally.
Cyryl
Dec 07, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
Dell Inspiron 9400 Notebook Logo
306 people viewed this question
Alun Cox
