Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp USB port not working
Hi..
I am facing a problem with my Dell TFT monitor 1907 fp...i.e. when i plug in any usb device in the monitor's usb port ..it does not recognise or show in my computer..
Can some one guide me what to do..or if i got to donwload usb driver for my tft..
thanx..
  • life0025 Jun 10, 2008
    Thanx for ur helpful reply..
    Actually i bought this monitor second hand..and i was not give this USB cable..
    Now according to ur suggestion i connected this cable with tft monitor and my pc...now USB devices are recognized..It solved my Problem..
    Thanks alot for ur help..
  • 3,940 Answers
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Posted on Jun 09, 2008
  • IQUIT Jun 10, 2008
    Not meaning to be picky, but if my answer resolved your problem, doesn't it deserve a FIXYA! rating?
Usb ports dont seem to work
In order for the usb ports to work you must have 1 usb from the computer connected to the monitor. The monitor may have a specific input port from the pc in order to activate the other ports on the monitor
Mar 22, 2014 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
I do not know how to make my dell monitor usb ports active please help me
  • Check that your monitor is turned ON.
  • Reconnect the upstream cable to your computer.
  • Reconnect the USB peripherals (downstream connector).
  • Switch off and then turn on the monitor again.
Jan 19, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
HI SIR MY LCD IS Dell 1704FPVs 14" IF WE
You can only use this connector after you have connected the USB cable to the computer and USB upstream connector on the monitor.And u need to Purchase this Cable Seperatly u dont Get with the Box.
Click on this Link if u Need More Clarification
http://support.dell.com/support/edocs/monitors/1704FPVS/EN/about.htm#Bottom View
Jul 18, 2009 | Dell 1704FPVs 17" TFT LCD Flat Panel...
My 2 usb ports on my monitor not working
In order for the two USB ports on the monitor to work, the monitor itself has to be connected to your computer via another USB cable with connectors that look like this:
The flat connector goes into an available USB port on your computer, the square one plugs into your monitor. Check if your cable is connected properly or exchange it with another one.
To eliminate that there is something wrong with your "not recognized device", plug this device into another USB port of your computer. The reason to preferably remove the device safely in Windows is that you can loose data if you just unplug it. If it is an external harddrive, it can get damaged, because you interrupt the power and the read/write head can get "stuck". So check this device on another computer or USB port.
If you have any other questions or something is not clear to you, just come back here and leave a comment and I'm happy to help.
Apr 13, 2009 | Computers & Internet
Usb ports on 1703fpt do not work
you have to connect the monitor with a usb cable to your computer, then you can use its usb ports, it's just a hub.
Mar 28, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Activate USBs on monitor
USB slots on a monitor act as a USB hub, and thus need a USB cable to connect from the monitor to the computer. Check the plug type on the monitor, if will either look likea normal USB plug in near the power and video cables or it might look a little more square; simply get a USB cable of this type (Type A for normal, type B for squarish) to connect from your monitor to a normal USB plug on your computer ( Normal being type A), and it should work.
Mar 12, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
USB outlets
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
Aug 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Monitor usb
There should be a USB cable from one of the usb ports on your computer to a small square (upstream) USB port on the back of your monitor. This will activate the four (downstream) usb ports on your monitor.
Good luck...and I hope this is helpful!!
Feb 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
2,297 people viewed this question
Alun Cox
