Question about Samsung Refrigerators
Every 3 - 4 weeks i have to defrost my samsung side by side fridge freezer with a hair dryer as the cooling system keeps icing up
  • 770 Answers
You have a defrost problem there are Three parts to it a Defrost control board a Defrost Heater and a Defrost bi-metal thermo-disc I would check the heater first it is in the coils you are defrosting
Posted on Jun 09, 2008
How can I defrost my Kitchenaid Superba Freezer without unplugging the entire unit?
the air from the freezer is what cools the fridge so no way to separate the cooling process for defrost
Apr 24, 2017 | KitchenAid Superba KSRS27CN Side by Side...
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
Samsung fridge not working freezer is?
sounds like you removed the defrost tstat.you need to replace it.if your evap coil ices up it will block the cold air flow to the frige section.replace your bad part so your defrost system willwork
Nov 27, 2012 | Samsung Refrigerators
Side by side fridge freezer
That sounds like one of your cooling tubes is frosted up IF your fan is working. Pull the read freezer shield off and check for an ice buildup around the evaporator coil. If so, defrost circuit problems. If not, use a hair dryer and blow air down the cooling tubes to defrost the tubes.
Jan 23, 2012 | Refrigerators
My whirlpool fridge is not working, the freezer is working, I can't understand it. The thermostat inside the fridge seems to be okay, inside the fridge is not even cold. Can you help me. My fridge...
Your cooling comes from the freezer side through cooling tubes to the refrigerator side.
The first thing is to make sure that the evaporator fan is working, because that will blow the cold air into the refrigerator side. If it is working then you probably have an ice build up around the evaporator. You will need to remove the inner rear panel of the freezer to check it.
If there is a lot of ice on the evaporator fins then your defrost circuit is not working. But if you manually defrost the freezer (a hair dryer will speed it up) and make sure the cooling tubes are clean of ice (can feel the air from the hair dryer on refrigerator side) then you will have anywhere from a few days to a few weeks before the ice build up returns.
So you should troubleshoot your defrost circuit and get the parts on order to be ready for the next time.
Jul 15, 2011 | Whirlpool Refrigerators
Freezer is icing up behind back panel, so fridge not cooling
There are two components that are supposed to take care of this problem. One is a heater that defrosts the system (not really frost free) and the other is a timer that turns the heater on and off at predetermined intervals.
If the heater or timer fails, the system will frost up and block the path of cool air not allowing the freezer to cool down.
Jul 20, 2009 | GALAXY Microsystems 63702 Top Freezer...
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost problem.you will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Refrigerators Logo
245 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
