Question about Crosley CAWC529JQ Top Load Washer
Hot water i just bought a new washer and dryer [crosley]. my hot water runs real slow and will sometimes switch to warm and then back to hot. i took the water line off and ran it into a bucket and it had plenty of water pressure.
    Genius:
  • 1,028 Answers
New washer valve on washers are designed to be "energy saving" most are 70/30..on warm 70 percent cold and 30 percent hot also new temp controls will reduce temp to a "safe level" by adding cold even on hot setting the on/off of water flow is being controlled by thermal sensor in water line on valve output ..in other words it's normal
Posted on Jun 10, 2008
My washing machine won't work on cold water but it will on warm and hot water but the warm water actually be hot and it won't spin. what could the problem be?
Cold water inlet solenoid is not working or the inlet screen is plugged. Unhook the cold water hose from the washer and see if the screen isn't plugged. If not, then the solenoid that controls the water isn't working.
Jul 17, 2014 | Crosley Washing Machines
My machine sometimes will not start when using just cold water. I don't have it hooked up to the hot water faucet because I don't use hot water. I switched the cold water hook up hose to the hot water...
If you live in or near a big city, there is a part you might use that might solve this problem. I bought one for my daughter's house. It is a "split hose", it is in the shape of a "Y". You screw the bottom of the "y" to the water outlet, then screw the top two legs of the "Y" to each of the connectors on the back of the machine, means you have whatever water that the Y is hooked to going in to both of the connections on the back of your machine.
Be blessed.
Oct 06, 2013 | Kenmore 2.1 cu. ft. Portable Top Load...
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
We have hot water but no cold water. My washer for a long time spit cold water out real slow then it stoped I checked the hoses and little filter going in to washer it was clean i hear it humming but no...
Start by disconnecting the washer from the cold water hookup, and screw a garden hose to the cold water pipe, running the garden hose to the outside. Then, turn on the faucet to the cold water, and see how it flows out the hose.If it is good, your problem in inside the machine.
You will need to dismantle the washer and inspect the cold water inlet to see if it is plugged up. Sounds like it is. "Sears Parts" online will show you a parts schematic for your machine by model number. They will also show you a parts list. " e-bay" offers new and used washer parts.
Be blessed.
Sep 14, 2011 | GE Washing Machines
Just bought a second hand 40hp tohatsu took it out bu water was not continuly coming out when motor is running have stripped down and parks all look ok in shaft. Also what gasket sealer should i use when...
you have a thermostate water will come out real slow till it warms up should get full stream when full open if not change water pump and thermostate
Jan 03, 2011 | Boating
Washer Won't Fill, New fill Valve, makes humming noise
Check your water level switch it may be showing full. If it is it won't fill. If you can set it on spin and run for 2 or 3 min. it might clear the hose from the tub to the switch in case there is too much water in it. Or you could pull the hose off the switch and blow in it to be sure it is clear. Sometime if it gets too much in it it builds up too much pressure and shows full.
Jun 09, 2009 | Washing Machines
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
Very slow cold water flow
soundslike either your cold water supply is not turned on all the way or the inlet valve is clogged w/debris. try removing cold water hose and checkin inside the valve, sometimed youll be able to remove sediment adn debris from valve from screen, if thats not the case youll need to replace the vavle itself
Apr 17, 2008 | Maytag MAV2755A Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
128 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jdthefixer
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
