Question about RCA MM61110 61" Rear Projection Television
RCA MM61110 Problems
My tv comes on, plays for a few minutes, then clicks off and on two or three times and then just stays off.
I did unplug tv for 24 hours and plug it back in, but it does the same thing.
I took the back panel off and noticed that one of the cooling fans was not working..... apparently the computer tells the tv that it will not be able to cool. I cleaned things using air and basically followed the wires for the cooling fan and wiggled them... lol.. works fine now
Posted on Mar 26, 2009
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
Set will often have problems starting back up
you have a high voltage arching problem. the crt has about 33000. (thirty three thousand) volts on it. the anode lead is arching to the chassis(ground) around the crt(picture tube). the anode lead is the big red wire on the very top of back of crt. with the back off, you will see the big red wire and it will have a suction cup about 4 inches round connecting to picture tube. unplug. silicone around suction cup. let dry for 24 hours. enjoy. you might get a little shocked even when unplugged, but wont hurt you.
Nov 12, 2009 | RCA MM36100 36" TV
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Clicking
thats the power supply trying to fire up but there is a fault.
Nov 15, 2007 | RCA MM61110 61" Rear Projection Television
TV turning on and off
Try reset.Unplug AC cord for a few minutes, longer,if doesn't work.plug back in--try again.
Oct 09, 2007 | RCA 32V420T 32" TV
RCA MM61110 61" Rear Projection Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
