Help maytag tech said there is build up around agitator in between tud and rubber tub how do you clean this out
    Genius:
  • 1,073 Answers
Dissasemble the basket from the tub, did he not tell you how when he was there??????????
Posted on Jun 09, 2008
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
I have a Maytag Model MHWE300VW11, Serial CSW5002000 and the clothes never smell fresh. There is always a mild sour smell. I always wipe out the washer and wipe all around the gasket in the tub and I...
you could look for a build up of muck- old soap powder etc around the main door rubber, there are places where the muck will collect. put your fingers right inside the door rubber as there are gaps that are hidden . this muck builds up and causes a horrible smell
Aug 29, 2010 | Maytag Washing Machines
Washer tub has come loose, it still agitates, its just way to loose
a washer tud is lose were when it go in to spin that help stay in balance
Apr 24, 2010 | GE WJSR2070B Top Load Washer
My Maytag Neptune smells very musty. I have used vinegar, baking soda, and bleach but the smell wont go away!!!
This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How to replace tub seal on Maytag sav4655eww
you need a 1/4" nut driver and a spanner wrench-start by taking 1/4" screw located toward lower part of agitator,its recessed,take it out,then lift out agitator, then mark where your drum is so you get replaced in that location(counter-weights)then take spanner wrench and loosen nut that holds the wash tub and lift out tub,turn tub over and w/rubber mallet driveout old seal,to aid in new seal install lightly lube with vegetable oil(wessonoil-pam cooking spray) and tap seal into place and re-install in reverse order
Jul 26, 2009 | Maytag Washing Machines
My maytag washer is throwing off a musty stentch. What should I do about this? It is stinking up my laundry room and the entrance to my condo.
There is a soap buildup underneath your agitator. Look for a screw on the outside of your agitator just above the lower large part with the agitatotr blades. Memory is fading but it is either a 5/16 or 1/4 ince socket that will be required to remove the screw. Once the screw is removed simply lift the agitator out then begin cleaning the tub with PLASTIC bladed putty knife. As for the agitator use something like Mr Muscle or Eliminate to clean the botttom and inside of the agitator itself. (any product that will remove soap or calcium buildup) \You can also use those same products to clean what is still on the top face of the inside bottom of your wash tub. Once you finish cleaning simply align the splines on the agitator and re-install the screw. You will NOT damage your machine running it empty. Make sure you run at least a full rinse cycle before washing clothes again as there will be some residue that will need to be washed out of your machine. Once you install the agitator push the tub stiffly in 90 deg quadrants and look at the top of your wash tub cover. Soap build up in that area can also result in an odor. The is something you can do yourself. Good Luck.
Jul 19, 2009 | Maytag Admiral AAV7000A
Amana ALW780QAW mold in agitator
actually sounds like fabric softener residue with dirt mixed in...it's almost like a wax if thats it. probably just have to clean it regularly..good luck! :)
Jun 14, 2009 | Amana ALW880WH Top Load Washer
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
