Question about Maytag M6Y12F2A Air Conditioner
Temp control moves on it's own
I set the temp control on my AC to 68. After about an hour or two of running fine, it moves on it's own down to 30 and sometimes 20 and it beeps as the number moves down as if someone is pushing the button. The unit stops cooling and only the fan runs untill I hold both the up and down buttons. It then resets to around 78 and I am able to use the down arrow to set it to 68 again. At that point, it works fine for a couple of hours again, and then the process starts over again. (I clean the filter on a regular basis, once a week.)
  • jaspaper Sep 01, 2008
    THis is where it all starts. I have had this unit for 18 months and last year the control pannel started acting up. This year it got really bad and got to the point I couldn't hardly do any thing with it. When I removed the control pannel it was covered with corosion (moisture). I cleaned it up and got it to somewhat work again. Three weeks later the blower motor has locked up. I beleive that water from the condensor is not getting out of the unit properly and is wreaking havock inside the case. Once removed and the outer case taken off the whole inside of the unit had corosion and had a very bad stench. There was almost a 1/2" of stinky slime/mud on the bottom pan. You could phisically see where the fan blade had been throwing water around inside the case. I beleive Maytag/Feddres? has a problem with this one. Reinstalled my 30 year old Amana the has been sitting since I bought this one and It works great. Does anyone build a product that lasts any more?
  • 3 Answers
Mine was doing the same thing and it was really frustrating! I would come home and it would be 88* inside. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Posted on Jul 08, 2008
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
Just moved into an apartment with a Honeywell RTH111B. When I got here it was 75, five hours later it's still 75 even though I set it for 68. Any hope I can get to a comfortable (for me) temp?
Temp depends upon ur action of opening and closing door frequently and also depends on your system whether filters are cleaned or not. Plz check.
Sep 02, 2015 | Honeywell Heating & Cooling
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
2003 yukonxl tempture gadges asking up
Had similar problem. Air temp.was 95 degress or more and I was running the ac setting still. Temp gauge went up to 240 or 250. I increased te rpms while sitting still and temp came down. Once I starting moving temp came down to normal operating limit.
Jun 06, 2012 | 2003 GMC Yukon XL
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
Ac controls for eletronic control
could be a problem with the blend door. common on explorers. open glove box all the way down (bend in tabs to where it will open further than normal) . take flashlight and look behind it to top of black box inside dash. should be able to see tab for door moving while changing the temp. on the control unit. if it is broken should be able to hear cracking or popping from inside heater case.
Feb 18, 2010 | 1996 Ford Explorer
Honeywell programable thermostat not recognizing nigh time settin
This is the problem you have when you rely on "modern electronics". Suggest you buy a manual 'stat and just turn down the temp at bedtime. Make it cold and use a blanket, that is what we did in the " good 'ole days".
Jan 12, 2009 | Honeywell Programmable Heat Pump...
1994 Buick LeSabre equipped with the "Dual Automatic Temp Control
fault temp sensors
still can be a worn or stuck shaft flap at the actuators
or actuators is still faulty
Mar 07, 2017 | 2000 Buick LeSabre
Maytag M6Y12F2A Air Conditioner Logo
293 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
