Question about Electrolux Epic 6500 Vacuum
Rc light my 6500 wont work the rc light is on what does this mean
  • dogshiner Jun 22, 2008
    Plug light stays on electrolux Epic 6500 why? It seems to run ok other than light on.
    Problem Solver:
  • 7 Answers
For some reason power is running into the line that supplies that light. It's usually nothing.
Posted on Oct 29, 2008
What does it mean when the vacuum electricity light is on but no power and the ? mark is also lit up
The electricity light means there is powewr to the vacuum.The ? means there is not bag or the vacuum doesn't detect a bag.If so there is a little swich that is pushed down when closing the front cover.Make sure it goes down when closing.It is located where the top of the carboard of the bag top...Chris
Jul 11, 2014 | Electrolux Epic 6500 Vacuum
Electrolux 6500 sr what do the symbols on top of the canister mean when they are red?
the red symbol probably is the temperature light.This means you motor is over heated.Check hose,wand and power head for a block...Chris
Jun 06, 2014 | Electrolux Epic 6500 Vacuum
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
Light on 6000sr canister electrolux wont turn back on??turned dial whats it for?
The dial on the top of the unit sets the carpet height. The bulb needs replaced.
Sep 17, 2013 | Electrolux Epic 6500 Vacuum
How do you replace switch on Epic 6500 vaccum
You may need a ROCKER device for the switch, however before you go there determine if you can hear an audible click when depressing the switch, or if the switch just springs up and down with no click.
A click means a rocker is needed. No click, just springing up and down with an occasional click means the spring attached to the underside of the switch button is fatigued, you need the button and switch mechanism, same location but above the rocker.
Also post the issue. If the lights are on and the vac won't start or stop, the switch is the problem area. If it starts and shuts off with the bag full light on it is more likely the control valve. If no lights come on your problem is in the cord or rewind and could be a failed rewind spool.
The best and genuine switch parts are best found only at an AERUS Elctrolux store
Look for my post from earlier today and you will have full instructions on opening and checking the control valve and the entire unit.
Post back with results
Dec 23, 2009 | Vacuums
What does the warning light with question mark mean on the Electrolux Epic 6500 SR canister?
It means to check the bag. Your bag is either missing or misaligned and has slipped past the little clear sensor or bag lockout plunger in the corner of the bag chamber at the door.
Remove the bag turn on the vac and push this switch, the vac should start when the switch is depressed. If not the internal switch inside the vac is misaligned or damaged. Please post back to confirm how you make out
Oct 13, 2009 | Electrolux Epic 6500 Vacuum
What does the question mark light mean?
There is no bag in the vacuum, or the bag is not placed in the vacuum correctly.
In the lower corner of the bag holder near the door is a little black switch, this switch must be pushed in for the vacuum to run. This is a safety so you cannot clean without a bag in the machine.
May 19, 2009 | Electrolux Epic 6500 Vacuum
Does the epic 6500 sr have to have a bag in it to start?
Yes, you must have a bag in it for it to run. This is a protection feature so that the motor isn't damaged. You can bypass it just to see if it runs by depressing the small button in the lower front right hand corner of the bag housing. If you open the front, you should see it. Just press it while the machine is switched to "on", and it should come on. Good Luck, and great buy!!
Nov 25, 2008 | Electrolux Epic 6500 Vacuum
Electrolux 6500 SR
The cord light just indicates that the machine is plugged in and has power. In other words, you did great!
Nov 20, 2008 | Electrolux Epic 6500 Vacuum
Warning Light
Check the hose and wands for a clog. Usually that light means a full bag, but a clog or restriction will also cause it to come on.
Aug 18, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
63 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
