Question about AcerPower Sn PC Desktop
SET UP COMPUTER
I HAVE AN ACER POWER F2 DESKTOP WITH NEW HARD DRIVE (NO OS INSTALLED), ACER STARTUP DISK, AND ACER RECOVERY DISK AND WANT TO SET UP THIS COMPUTER. WHEN I TRY BOOTING FROM START UP DISK AND RECOVERY DISK I GET AN ERROR SAYING DESTINATION DRIVE INVALID. IS THIS BECAUSE THERE IS NO OS PARTITION SET UP? WHAT DO I NEED TO DO TO MAKE THIS WORK?
    Sergeant:
    Champion:
  • 326 Answers
Check the bios and make sure the hd is there. There should be a program on the cd or recovery disk to fdisk the hd (partitioning). Look at the dir on the disk and see whats there.
Posted on Jun 09, 2008
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
Problem is that I have just installed a new hard drive in my Acer Aspire 5315 or is it 5135. All this after I have set up in the f2 start up page for the cd rom to be the boot drive and a windows...
This issue may occur if one or more of the following conditions exist:
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
    Note Some third-party programs or disk corruption can damage an MBR.
  • An incompatible partition is marked as Active.
  • A partition that contains the MBR is no longer active.
To solve this, try one or more of the following solutions:
Verify your BIOS settings.. uparrow.gifVerify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk.The documentation that came with the hard disk should aid you in doing so.
Use Recovery Console..Use the fixmbr command in the Windows XP Recovery (or relevant OS) Console to repair the MBR of the startup partition. Be sure that a virus isn't present on the system and that their aren't any hardware errors as this could prove fatal to your hard disk.
May 06, 2011 | Acer Aspire 5315 Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I just installed a new hard drive to the Aspire E500. When i boot with xp os it i says there is not hard drive found. it goes to a blue error screen, what is my problem?
check the juumper setting on the hard disk, the picture is given on the hard disk. set it on the primary, then again connect the hard disk and start your computer again
Sep 14, 2010 | Acer Aspire E500 PC Desktop
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
Acer T-180 hangs at "Verifying DMI Data"
The cause of this problems is a corrupt boot files, Settings for hard disk drive are not correct,Floppy diskette or CD in computer causing issue, Boot devices not set properly, BIOS corrupt or misc. hard disk jumper setting not set properly, Connections loose or disconnected, Bad Hard disk drive or other bad hardware.
Note: Try this first. Check the cable setting of your hard disk in the BIOS. try swithching it to IDE, SATA, RAID. save your seetings and restart your computer.
if problem still exist... Follow this steps..
Step 1: If you have a USB stick with capacity of 4Gb and up or another hard disk... try installing a fresh Operating System in the USB stick or in the extra hard disk that you have.. after you install.. boot to bios and set the Primary boot in the extra hard disk or Removable Device (USB) save your settings and restart.. your computer will start normally booting the windows in your newly installed extra hard disk or USB stick. when you are in the Desktop, now try accessing your old hard disk and copy your files.. after you backup your files to the new installed hard disk. go to step 2.
Step 2: Turn off your computer... uninstalled the newly installed hard disk or USB.. after you uninstalled the hardware.. turn on your computer and reinstall your Operating System again. if the problem still exist go to step 3.
Step 3: if the problem stil exist. i think ther is something wrong with your hard disk.. try installing the OS again in second partitioned of your hard disk.. create first partition, then second partition. then installed your OS in second partition... if the problem still exist and you cannot go to windows desktop.. maybe your hard disk drive is damaged...
Hope I Can Help
CLCTECH
Apr 23, 2009 | Acer Aspire™ T180 PC Desktop
Reinstalling Vista and Acer Tech Cont.
boot from a windows vista dvd, choose language click ok, then at then choose repair option, from there you may choose complete recovery option which will reinstall vista or to repair startup options
Feb 10, 2009 | Acer Aspire 5610-4648 Notebook
Acer Desktop won't boot after recovery
Why not use your new hard drive as a storage disc. Reconnect your old hard drive as it was before. Hopefully it will boot the computer again. If it does, shut down the unit. On the primary bus, set your old HD as master & the new HD as slave with jumpers. Boot the unit & hopefully you will now have a "c"&"d" HD showing in My Computer. Remember that your are dealing with Windows & what should happen & what really happens can be two entirely different things.
Dec 14, 2008 | Acer Aspire™ T180 PC Desktop
Setting up a new hard disk and operating system on an Acer Power SC
There should be more than one disk, as the other will be drivers, all you need to do is press F2 or Del to get into your pc's bios settings and change the first boot device to your cd drive, insert your acer disc into the drive, then save the bios settings, restart the pc ,then, when prompted on screen to press enter to boot from cd; do so.
You should then follow instructions to set up windows on the 'C' drive as is default and it may need to reformat in NTFS.
Sep 08, 2008 | AcerPower 4300 PC Desktop
AcerPower Sn PC Desktop Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
