I am trying to hook up to my copmputer for recordings and have horrible feedback?
    Novelist:
    Scholar:
  • 100 Answers
Salutations welove2scuba,
I would first ask how you are connecting the computer, it would be best to use a "Line In" jack to your computer if you have one. Using the microphone jack could cause issues as it is a powered connection and could be causing your feedback.
A good way to connect a computer to a receiver would be to treat it as if it were a cassette recorder. Most receivers will have a "Play (out)" and "Rec (in)" for a cassette deck, or DVD recorder and in some cases VCR's. If you connect the "Rec (in)" to the "Line In" jack, this should give you a clean signal with out any additional amplification to avoid interference.
Cordially,
Jon
Go Ahead. Use Us.
Posted on Jun 09, 2008
How do I switch off the microphone to stop the speakers feeding back on my laptop. And how to set the levels when I am recording, to stop feedback.
I think it won't be possible to get rid of the feedback and quality will be poor when recording this way. Try software like Audacity and set the audio source to record directly from the sound card. The input device should be set to "Windows WASAPI" for Windows and output set to a loopback device.
How to Record the Sound Coming From Your PC Even Without Stereo Mix
Feb 11, 2016 | Dell Inspiron 15 5000 Series Laptop...
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
Backpanel socket for microphone is not recognised. Speaker socket is alright.
in order to hear sound on the microphone you need to check the Mixer settings as the default setting for microphone (for playback) is mute as you would get some horrible feedback..
double click on the speaker icon in the bottom left and chose properties from the options menu you may (or may not) have the option to select microphone for playback, however there should be a setting for recording which should give you a slider to set the recording levels for the microphone, use sound recorder or other recording software to test microphone is working
Apr 13, 2009 | Intel Motherboard
Feedback when trying to record with Audacity
Try turning down your speaker volume. This can cause feedback and is what the problem is.
Hope this helps. Bud
Jan 24, 2009 | Logitech Webcam
Quiet Noisey feedback out of speakers
The speakers are not hooked up correctly. I don't know if you still have the instructions but it is a hardware problem and not software. Try to figure out how to hook them up correctly.
Dec 27, 2008 | Dell Inspiron 1521 Laptop
Feedback noise from mixer
Your mixer is already grounded, and does not need any additional grounding. It is grounded through the Power Cord.
Now, the feedback might be coming from one of the units you have connected to the mixer. The issue could also be the cable you are connecting to your recorder. Are you recording to a computer, or to some other external recorder (CDR / DVR / MDR, etc?) - try a different cable. Also try the different outputs on the mixer - you have 2 balanced line outputs you can record directly from. Don't use the RECORD OUT line, it's an unbalanced line, and if you want a good quality signal to record, your best bet is to use the XLR outputs. However, that might be connected to your amp or something.
What do you have going to the unit? Disconnect everything, and try by connecting each item 1 by 1, to eliminate where this feedback is coming from. Also, check for any ground loops that you might have, if you have a lot of equipment hooked up in your set up. (Educate yourself on Ground Loops)
If all else fails, get yourself a HUM ELIMINATOR.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
54 people viewed this question
 Grubhead
Grubhead
