The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
SOURCE: picture is warped (three colors diverge at edges
WS-55857 uses two STK-392-570 convergence IC's----you may have bad solder connections on them but what is more likely(I have seen this in sets that Mitsubishi made that use this chip) is that some of the pins are broken loose inside one or both of the chips.
Considering the labor to get the board out to resolder it, might as well just replace BOTH of the chips------Usually this repair can be done right in your home and takes about an hour.
If you are able to do it yourself you can buy both chips for less than 15 dollars on Ebay; if you need help I have complete step by step instructions for this repair that tells what you need and how to do the repair---if interested I can email them to you.
If you are not able to do the repair most shops charge 300-400 for this kind of repair; look in your area and if they say "needs to go to shop" keep looking; any good tech can do this repair right in your home.
Now is the slow time of year for TV repair shops so look around--I do this kind of repair here for 200-250 depending on the set --right in someones home! I have done hundreds of these sets.
If you need any help or would like the instructions reply to this comment here.
I do this for free here so if it helped you take a minute and give me a vote here.
SD TECH
SOURCE: warpped TV picture
There are two problems here but may be caused by one component
The flyback transformer or transistor equivalent is faulty The colors are warped convergence controls which may be due to a faulty sustain board or part of the first problem. DIY is not an option and repair estimate is about $3-400.00
Please rate my help++++Thanks for uyisng FIXYA
